土木在线论坛 \ 建筑结构 \ ANSYS \ 中厚板焊接问题,求解过程总是出现问题,求助高人!
发布于:2011-12-01 15:54:01 来自:建筑结构/ANSYS [复制转发]
命令流如下:求助高人,帮忙解决问题
错误文件中总是出现这样的警告,无法得到最终的结果
这是刚刚运行时出现的错误文件,ansys会自动关闭,请高手帮忙解决,小弟感激不尽!
** WARNING ** CP = 6.438 TIME= 11:04:02
Node 71 on element 541 is unselected.
Node 30 on element 541 is unselected.
Node 2379 on element 541 is unselected.
Node 1219 on element 541 is unselected.
Node 2379 on element 542 is unselected.
** WARNING ** SUPPRESSED MESSAGE CP = 6.438 TIME= 11:04:02
Node 1219 on element 542 is unselected.
Node 2380 on element 542 is unselected.
/COM,
/COM,Preferences for GUI filtering have been set to display:
/COM, Thermal
/PREP7
ET,1,PLANE55
ET,2,SOLID70
MPTEMP,,,,,,,,
MPTEMP,1,0
MPTEMP,2,100
MPTEMP,3,200
MPTEMP,4,300
MPTEMP,5,400
MPTEMP,6,500
MPTEMP,7,600
MPTEMP,8,700
MPTEMP,9,900
MPTEMP,10,1000
MPTEMP,11,1200
MPDATA,KXX,1,,43.2
MPDATA,KXX,1,,43.2
MPDATA,KXX,1,,43.2
MPDATA,KXX,1,,43.2
MPDATA,KXX,1,,41.8
MPDATA,KXX,1,,40.3
MPDATA,KXX,1,,39.6
MPDATA,KXX,1,,37.8
MPDATA,KXX,1,,34.2
MPDATA,KXX,1,,32.4
MPDATA,KXX,1,,28.8
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,7850
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,C,1,,670
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,2,,39.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,2,,8900
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,C,2,,385
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,3,,25.4
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,3,,6900
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,C,3,,702
K,1,0,0,0,
K,2,0,0.002,0,
K,3,0,0.006,0,
K,4,0.0029,0.006,0,
K,5,0.1008,0.006,0,
K,6,0.1008,0.002,0,
K,7,0.1008,0,0,
K,8,0.1008,-0.01,0,
K,9,0,-0.01,0,
K,10,0.0008,-0.01,0,
K,11,0.0008,0,0,
K,12,0.0008,0.002,0,
A,1,2,12,11
A,2,3,4,12
A,11,7,6,12
A,12,4,5,6
A,1,9,10,11
A,10,8,7,11
KGEN,2,9, , , , ,-0.1, ,0
LSTR,9,13
AGLUE,1,2,3,4,5,6
AATT,3,,1,0,1
AATT,3,,1,0,2
AATT,1,,1,0,3
AATT,1,,1,0,4
AATT,2,,1,0,5
AATT,2,,1,0,6
LESIZE,1, , ,3, , , , ,1
LESIZE,3, , ,3, , , , ,1
LESIZE,5, , ,3, , , , ,1
LESIZE,7, , ,3, , , , ,1
LESIZE,9, , ,3, , , , ,1
LESIZE,12, , ,3, , , , ,1
LESIZE,13, , ,3, , , , ,1
LESIZE,15, , ,3, , , , ,1
LESIZE,17, , ,3, , , , ,1
LESIZE,2, , ,3, , , , ,1
LESIZE,4, , ,3, , , , ,1
LESIZE,6, , ,3, , , , ,1
LESIZE,14, , ,3, , , , ,1
LESIZE,8, , ,20,10, , , ,1
LESIZE,11, , ,20,10, , , ,1
LESIZE,16, , ,20,10, , , ,1
LESIZE,10, , ,20,0.1, , , ,1
AMESH,1,6,1
TYPE,2
EXTOPT,ESIZE,30,0,
EXTOPT,ACLEAR,1
EXTOPT,ATTR,1,0,0
VDRAG,1,2,3,4,5,6,18
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
EPLOT
SAVE
ALLSEL,ALL
ASEL,S,EXT
FLST,5,12,5,ORDE,8
FITEM,5,1
FITEM,5,-4
FITEM,5,11
FITEM,5,13
FITEM,5,15
FITEM,5,17
FITEM,5,19
FITEM,5,-22
ASEL,R, , ,P51X
NSLA,R,1
FINISH
/SOL
SF,ALL,CONV,200,25
ALLSEL,ALL
ASEL,S,EXT
FLST,5,7,5,ORDE,5
FITEM,5,5
FITEM,5,-6
FITEM,5,24
FITEM,5,26
FITEM,5,-29
ASEL,R, , ,P51X
NSLA,R,1
SF,ALL,CONV,100,25
ALLSEL,ALL
*GET,NMAX,NODE,,NUM,MAX, , , ,
*GET,EMAX,ELEM,,NUM,MAX, , , ,
SAVE
ALLSEL,ALL
VSEL,S,VOLU,,1,2,
/REPLOT
ALLSEL,BELOW,VOLU
*GET,AEMAX,ELEM,,NUM,MAX, , , ,
SAVE
*DIM,ANEO,ARRAY,AEMAX,1,1, , ,
*DIM,ANEZ,ARRAY,AEMAX,1,1, , ,
*DIM,ANEL,ARRAY,AEMAX,1,1, , ,
*SET,II,0
*DO,I,1,EMAX
*IF,ESEL(I),EQ,1,THEN
*SET,II,II+1
*SET,ANEO(II),I
*ENDIF
*ENDDO
*DO,I,1,AEMAX
*GET,ANEZ(I),ELEM,ANEO(I),CENT,Z
*ENDDO
TUNIF,25,
*DO,I,1,AEMAX
EKILL,ANEO(I)
*ENDDO
ANTYPE,4
TRNOPT,FULL
*SET,Z0,-0.1
*SET,V,0.00277
*SET,R0,0.1/30
*SET,MU,0.6
*SET,U,22
*SET,EI,160
*SET,T,0
*SET,DT,0.1/30/V
*SET,GENQ,U*EI*MU/7.2E-8
LUMPM,0
OUTRES,ALL,ALL
*DO,I,1,30
*SET,T,T+DT
*SET,ZMAX,Z0+V*T
*SET,ZMIN,Z0+V*T-R0
*SET,J,0
*DO,II,1,AEMAX
*IF,ANEZ(II),LE,ZMAX,THEN
*IF,ANEZ(II),GT,ZMIN,THEN
EALIVE,ANEO(II)
*SET,J,J+1
*SET,ANEL(J),ANEO(II)
*ENDIF
*ENDIF
*ENDDO
*SET,ANSEL,J
ESEL,S,LIVE
EPLOT
ESEL,ALL
*DO,K,1,ANSEL
BFE,ANEL(K),HGEN,,GENQ
*ENDDO
TIME,T
AUTOTS,1
NSUBST,4,,,1
KBC,1
TSRES,ERASE
SOLVE
*DO,JJ,1,ANSEL
BFEDELE,ANEL(JJ),HGEN
*ENDDO
*ENDDO
FINISH
  • h123_123456789
    错误文件已经说了:某些节点在求解时没有选择,建议在求解时选择全部节点。
    2011-12-02 13:59:02
ANSYS
4.39 万条内容 · 152 人订阅
判断两个面是否有交集
在ANSYS几何建模时,如何判断一个面是否和其他面相交,即有交集?谢谢各位大侠!
