土木在线论坛 \ 人才招聘 \ 学生专栏 \ 斑竹有空帮我翻译一下啊!急!万分感谢!!!
发布于:2006-08-11 10:49:11 来自:人才招聘/学生专栏 [复制转发]
Environmental Impact of the Supply Base
From a corporate perspective , some companies have attempted to address environmental issues through the supply chain. Their work concentrates on the up-stream part of the supply chain,i.e.,the suppliers. Both BT and B&Q have achieved a considerable amount in this field. BT have had a vendor assessment scheme incorporating environmental purchasing policy for over 4 years. B&Q use both questionnaires and auditors to track environmental issues in their supplier base and have decided that this approach is preferable to requiring environment management system implementation [14]. However, neither of these companies, nor any others ,consider environmental management principles into their supply chain organization. Lamming and Hampson [15] mention that "environmental pressures may be expected to increase in the future ," they suggest that "an effective means of dealing with them must be implemented through the purchasing function." Their paper concentrates on the supplier base of a company as the focus for supply chain environmental performance , but environmental performance criteria must be applied to the entire supply chain function to encompass the whole, not just the up-stream effects. Other organizations have focused on the opposite end of the supply chain with recycling issues. Equipment is returned from the customers of companies such as IBM, Nokia,BMW and Rank Xerox [16]. These companies either recondition the old equipment or reclaim the materials, reprocessing them into raw material. However , it appears that little work is being carried out into how to evaluate decisions concerning supply chain operations. The logistics discipline is well qualified to deal with cradle to grave issues because of logistics focus on supply chain management , which emphasizes the control of materials from suppliers, through value added processes and on to the customer. The interface between logistics and the environment is embedded in the value adding functions a firm performs [17]. As Wu and Dunn [18] quite rightly point out "to minimize total environmental impact , it must be evaluated from the total system perspective."
全部回复(5 )
  • andyhewitt
    andyhewitt 沙发
    去睡觉了 别忘记请客哦 嘿嘿!!!
    2006-08-12 13:53:12
  • andyhewitt
    andyhewitt 板凳
    终于翻完了 累
    2006-08-12 13:52:12
学生专栏
23.9 万条内容 · 138 人订阅
从施工单位到设计、科研单位真的那么难吗?
我是一个本科生,是学港海工程的,还有一年就毕业了,听别人说,现在干我们这一行最好的发展方法是先到施工单位去锻炼几年,再去设计单位或科研部门,这样发展空间最大,但问题是一旦到了施工单位就很难出来了,我不怕吃苦,我想问问我应该怎么办?
