土木在线论坛 \ 站务休闲 \ 闲聊茶吧 \ 英语734条高频词组
英语734条高频词组
发布于:2006-08-02 18:53:02 来自:站务休闲/闲聊茶吧 [复制转发]
1.abide by(=be faithful to ; obey)忠于;遵守。
2. be absent from…. 缺席,不在
3. absence or mind(=being absent-minded) 心不在焉
4. absorb(=take up the attention of)吸引…的注意力(被动语态)be absorbed i n 全神贯注于…近be engrossed in ; be lost in ; be rapt in ;be concentrated on ; be focused on ; be centered on
5. (be) abundant in(be rich in; be well supplied with) 富于,富有 6. access(to) (不可数名词) 能接近,进入,了解
7. by accident(=by chance, accidentally)偶然地,意外. Without accident(=safely) 安全地,
8. of one’s own accord(=without being asked; willingly; freely)自愿地 ,主 动地
9. in accord with 与…一致 . out of one’s accord with 同….不一致
10. with one accord (=with everybody agreeing)一致地
11. in accordance with (=in agreement with) 依照,根据
12. on one’s own account 1) 为了某人的缘故, 为了某人自己的利益 2) (=at one’s own risk) 自行负责 3) (=by oneself)依靠自己 on account 赊账; on account of 因为; on no account不论什么原因也不;of …account 有…..重要性.
13. take…into account(=consider)把...考虑进去
14. give sb. an account of 说明, 解释 (理由)
15. account for (=give an explanation or reason for) 解释, 说明.
16. on account of (=because of) 由于,因为.
17. on no account(=in no case, for no reason)绝不要,无论如何不要(放句首时句 子要倒装)
18. accuse…of…(=charge…with; blame sb. for sth. ; blame sth. on sb. ; complain about) 指控,控告
19. be accustomed to (=be in the habit of, be used to)习惯于.
20. be acquainted with(=to have knowledge of) 了解; (=to have met socially ) 熟悉
21. act on 奉行,按照…行动; act as 扮演; act for 代理
22. adapt oneself to(=adjust oneself to) 使自己适应于
23. adapt…(for) (=make sth. Suitable for a new need) 改编, 改写(以适应新的需要)
24. in addition (=besides) 此外, 又, 加之
25. in addition to(=as well as, besides, other than)除…外
26. adhere to (=abide by, conform to, comply with, cling to, insist on, pe rsist in, observe, opinion, belief ) 粘附; 坚持, 遵循
27. adjacent(=next to, close to) 毗邻的, 临近的
28. adjust..(to) (=change slightly)调节; 适应;
29. admit of (=be capable of, leave room for) …的可能,留有…的余地.
30. in advance (before in time) 预告, 事先.
31. to advantage 有利的,使优点更加突出地.
32. have an advantage over 胜过. have the advantage of 由于…处于有利条件 have the advantage of sb.知道某人所不知道的事
33. take advantage of (=make the best of, utilize, make use of, profit from, harness)利用.
34. agree with 赞同(某人意见) agree to 同意
35. in agreement (with) 同意, 一致
36. ahead of 在…之前, 超过…;……………. ahead of time 提前.
37. in the air 1)不肯定, 不具体. 2)在谣传中.
38. above all (=especially, most important of all) 尤其是, 最重要的.
39. in all (=counting everyone or everything, altogether) 总共, 总计
40. after all 毕竟,到底; (not) at all 一点也不; all at once(=suddenly)突然; once and for all 只此一次; above all 最重要的; first of all 首先; all in all 大体上说; be all in 累极了; all but 几乎.
41. allow for (=take into consideration, take into account) 考虑到, 估计到 .
42. amount to (=to be equal to) 总计, 等于.
43. answer for (undertake responsibility for, be liable for, take charge for) 对…负责.
44. answer to (=conform to) 适合,符合.
45. be anxious about 为…焦急不安; 或anxious for
46. apologize to sb. for sth. 为…向…道歉
47. appeal to sb. for sth. 为某事向某人呼吁. appeal to sb. 对某人有吸引力
48. apply to sb. for sth. 为…向…申请 ; apply for申请; apply to 适用.
49. apply to 与…有关;适用
50. approve of (=consent to, be in favor of, favor, agree to, consider good, right) 赞成, approve vt. 批准
全部回复(14 )
  • zhiyongfan
    zhiyongfan 沙发
    用于写作的非常好的词组,谢谢上传。我把资料整理成WORD文档,上传让大家共同学习
    2007-02-22 23:56:22
  • lmf200404@co163
    701. in turn (=successively; in order) 依次
    702. be typical of 是…的特点
    703. for use 以便使用
    704. be in use (=be used)被使用; be out of use (=be on longer used)不再被使用
    705. be used to+名词或动名词 习惯于 used to+动词原形 过去常常(做)
    706. be unprepared for 对…无准备的
    707. in vain (=uselessly) 徒劳
    708. be valid for 对…有效的
    709. in the vicinity 在附近; in close vicinity to 在靠近…的地方; in the vicinity of 大约
    710. with a view to +动名词 (=in order to do sth.) 以…为目的
    711. in view (=in sight) 看得见
    712. in view of (=considering) 考虑到… in the view of 按…的意思
    713. byin virtue of (=as a result of, by means of) 由于…; 依靠…力量
    714. a warning against 告诫…不要 a warning of 警告…存在…
    715. (be) on the watch for不断监视看有没有..
    (be) on the watch against不断监视为防范…
    716. be in the way (=obstructive) 碍事, 阻碍
    717. (be)under way (=moving forward)正进行
    718. by way of (=by going through) 经由,取道
    719. by the way(=in addition)顺带地(转移话题)
    720. in no way 无论怎样也不…
    721. in the way 对…方式
    722. in a way 从某种程度上说
    723. as a whole (=in general) 就整体而论
    724. on the whole (=generally, for the most part) 大体上说
    725. against one’s will 违心地, 违背意愿地 at will 随心所欲; with a will 有决心地
    726. wish for 渴望某物;hope for 想要某物
    727. “with+名词+分词” 构成复合结构,作状语
    728. word for word (=literally) 逐字地
    729. in a word总之;in other words 换言之; have a word with sb.谈一谈; have words with sb.争吵;have the last word有决定权 ; keep one’s word 遵守诺言
    730. work out ideas 出主意;work out the amount of…计算出…的数量;work out a
    problem解决问题;work out a puzzle解谜
    731. at the thought of一想到…worry about担心
    732. at (the) worst 在最糟的情况下
    733. yield to 对…屈服,投降,让步,顺从
    734. be worthy of (=be deserving of)值得,够得上, 配得上
    2006-08-02 19:23:02
闲聊茶吧
114.52 万条内容 · 201 人订阅
回忆是一种享受
回忆是一种享受,  它使人在漫无边际的记忆长河中寻找逝去的瞬间,  化作淡淡的怀想永远珍藏在心底。  花开花落,每一次冬去春归,  我都醉倒在酣畅的梦境中,呓语里分明呼唤着故乡的春天。
