土木在线论坛 \ 建筑结构 \ 钢结构工程 \ Strucad10.1钢结构详图软件
Strucad10.1钢结构详图软件
发布于:2006-08-02 10:45:02 来自:建筑结构/钢结构工程 [复制转发]
INSTALL METHOD
The first thing, before attempting to install the software, is to install the Sentinel Dongle Emulator following the instructions below:
Sentinel Emulator Installation procedure.
1. Double click the StruCAD.REG file which resides in the Crack folder. This adds a support for a key. You’ll get a window asking you for permission to add information to the registry. Answer "YES".
2. Then you need to install the Sentinel Emulator which again resides in the Crack folder as SentEmul.EXE. Double clicking on this file launches the Emulator programme.
3. Select destination directory and program group.
4. Select "Automatic Start" if you want to start driver instead of original sentinel driver and don’t use shortcuts to start driver.
5. Now reboot your computer.
Now you can install the software.
1. When asked if the programme should attempt to find a hardware lock, answer ‘No’.
2. Choose ‘Custom’ when asked for the type of installation and select all except StruCam.
3. When asked for the dongle code, use the following key: 46111113922222/4369 and click ‘Compile’
4. When asked if you want to install Microsoft.net frame, click ‘yes’
5. Reboot your computer again.
Finally, when you attempt do anything inside the programme, for the first time only, you will be asked for a password, use 45205903611719 for Strucad v10.1.
SETUP WEB:http://co.163.com/forum/content/1654_365569_1.htm
全部回复(22 )
  • chnxgd
    chnxgd 沙发
    谢谢,已安装,可以使用
    2007-06-22 14:07:22
  • sfymax
    sfymax 板凳
    支持你楼主
    多发表这样的精品对大家学习有很大的帮助
    谢谢你的努力!我们这些下载者会很好的利用你提供的资源!!
    2007-03-17 17:18:17
钢结构工程
46.53 万条内容 · 1223 人订阅
钢结构设计阶段的造价控制讨论
1、  由于国家政策、钢材生产、构件制作、设计研发、标准规范修订等方面的有利因素,近几年我国的建筑钢结构进入了一个全新的发展时期。新材料、新部品、新结构体系不断出现,钢结构设计研发、制作安装能力日益强大,建筑钢结构向多样性、适用性、经济性方向发展。  建筑钢结构的经济性能一直是大家最为关注的一个问题。如何控制工程造价,充分发挥钢结构建筑技术经济上的综合优势,工程设计阶段是关键阶段。据权威资料统计分析,在初步设计阶段,影响工程造价的可能性为75%-95%;在技术设计阶段,影响工程造价的可能性为35%-75%;在施工图设计阶段,影响工程造价的可能性为5%-35%。因此设计质量的好坏、设计是否优化对工程造价将产生直接的影响。下面以门式刚架轻钢结构厂房和多、高层钢结构建筑的设计为例,在材料选用、结构体系等方面进行简要分析,探讨在设计阶段控制工程造价,提高建筑经济性能的可行性。
