土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 关于钢筋阻锈剂功能讨论!
关于钢筋阻锈剂功能讨论!
发布于:2006-07-25 16:12:25 来自:建筑结构/混凝土结构 [复制转发]
请就你所知的钢筋阻锈剂功能发表一下讨论!!
全部回复(4 )
  • baibainian
    baibainian 沙发
    国外老工程修复中使用钢筋阻锈剂的问题仍然存在争议(请看文摘或全文):
    ——发展渗透型阻锈剂(MCI)以保护混凝土中钢筋以防腐蚀。用于已有混凝土结构的修复,可以加到混凝土修补砂浆中或者涂敷混凝土表面(渗透)
    Migrating corrosion inhibitors (MCI) were developed to protect steel rebar from corrosion in concrete. They were designed to be incorporated as an admixture during concrete batching or used for surface impregnation of existing concrete structures.
    (Materials Performance (USA). Vol. 38, no. 11, pp. 52-56. Nov. 1999)
    ——讨论了混凝土修复工业利用钢筋阻锈剂的问题。这类化学物质可以混合到修补混凝土中或者涂在硬混凝土表面渗透到钢筋,很显然,渗透过程更困难。掺入和表面涂敷两种情况,均缺乏资料和现场使用的数据。特别是阻锈剂通过硬混凝土的渗透,是需要评估的。在此方面,欧洲和美国的建筑业、运输业和中立派研究者正率先进行研究。
    Discusses the use of corrosion inhibitors for steel by the concrete repair industry. The chemical agents can either be mixed into fresh concrete or are applied to the surface (or in holes) of hardened concrete, permeating through to the internal steel reinforcement. Obviously the latter is a more difficult procedure, but in both cases there is a lack of information and field data about inhibitor performance. In particular, the claims made for the transport of inhibitors through hardened concrete need to be assessed. Research in this area is currently taking place, however, in both Europe and the US by building and transport establishments and independent researchers.
    ( Concrete. Vol. 33, no. 6, pp. 44, 46-7. June 1999 )
    ——加拿大IRC在已有的10跨混凝土桥上进行了试验研究,使用了8种阻锈剂(有机和无机类)。试验室研究表明,一种有机类和一种无机类对降低腐蚀很有效;但现场试验表明,仅一种无机阻锈剂比较好。
    IRC researchers selected 10 consecutive spans of the bridge for testing. Eight organic and inorganic corrosion-inhibiting systems were applied to the spans。A series of comparative laboratory experiments showed that one of the organic-based admixtures and one of the inorganic-based admixtures were very effective in reducing corrosion. In the field, however, the
    inorganic-based inhibitor system performed better than the other inhibitor systems.
    ( CONSTRUCTION INNOVATION Volume 7 Number 3, September 2002)
    ——钢筋混凝土桥梁修复利用钢筋阻锈剂的长期有效性(美国联邦公路局报告)
    为了确定钢筋阻锈剂的长期有效能,美国联邦公路局(FHWA)于1994—1999年的5年时间,进行了现场试验研究。所有4个使用场地的腐蚀速率的测试结果表明,含与不含阻锈剂的修补砂浆,其效果没有显示出差别来。
    (注:本报告全文共58页)
    Long-Term Performance of Corrosion Inhibitors Used in Repair of Reinforced Concrete
    Bridge Components
    Publication No. FHWA-RD-01-097
    the Federal Highway Administration (FHWA) in August 1994 and ended in July 1999. The primary goal of this study was to monitor the SHRP field sites for 5 years to determine the long-term effectiveness of corrosion inhibitors。
    At all four sites, the results of the visual and delamination surveys and corrosion rate measurements did not show any difference between patches containing corrosion inhibitors and those that did not contain them.
    2006-09-11 10:56:11
  • baibainian
    baibainian 板凳
    洪乃丰先生是我国早期研究钢筋阻锈剂的科研工作者,他的网页上有较全面的论述,你不妨去查看一下。网址是:
    www.hongf.com
    2006-08-28 09:46:28
140.17 万条内容 · 2232 人订阅
混凝土结构设计规范GB 50010_2002
希望对大家有帮助
