土木在线论坛 \ 站务休闲 \ 闲聊茶吧 \ 国外摄影作品欣赏
国外摄影作品欣赏
发布于:2006-07-08 18:46:08 来自:站务休闲/闲聊茶吧 [复制转发]
全部回复(8 )
  • glian.c
    glian.c 沙发
    这种帮助无异于雪中送炭。不要计较太多,你的善心会得到回报的。
    这是公理。。。
    2006-07-09 09:33:09
  • lmf200404@co163
    办公室怎样与同事相处:勤劳肯干总不是错的
    Office protocol can make it difficult for one employee to ask another for help. While no one likes the shirker who never seems to be able to quite get his own projects finished and turns helplessly to peers for assistance, most will willingly volunteer to lend a hand to someone who has helped him or her before. 勤劳肯干总不是错的。
    If you know a coworker is working through lunch on a large client packet, your volunteering to stay and help will be gratefully received and most often returned when it’s you who is stuck. I say voluntarily because your offer does not add up paid overtime hours. It is only helping a peer in need. 这种帮助无异于雪中送炭。不要计较太多,你的善心会得到回报的。
    If your offer is accepted, you do not, however, store it away in your mental favor bank or ever remind everyone what a good person you were for helping--you simply hope the favor will be returned when it’s you who is overloaded. 一旦你的好意被接受,不要刻意地老记着或提醒每个人您曾如何地帮助过他们--在你遇到力不从心的情况下总会有人回报你的。
    2006-07-08 18:54:08
闲聊茶吧
114.52 万条内容 · 196 人订阅
你删除过你最爱的人的POPO吗/
时间过了,缘分淡了,相爱的人也就散了,真的是这样吗? 终于还是走到了感情的尽头,结局最终还是要分手。 可是你却选择了默默的离开,连“分手”这个词都没有对我说出口。留给我的只有伤心和眼泪。谁说“男儿有泪不轻弹”,却不知“只因未到伤心处”。伤过心后我想彻底把她忘记,就把她的POPO拉到陌生人了。 也许是真的没有下定决心忘记她,有时候我也会自问“为什么不直接拉到黑名单里?” 那样可以更干脆的忘记 。
