土木在线论坛 \ 建筑结构 \ 结构设计软件 \ 求助:sap2000警告
求助:sap2000警告
发布于:2006-07-04 10:22:04 来自:建筑结构/结构设计软件 [复制转发]
我用sap2000计算地铁地下车站,模型取支撑在弹性地基梁上的平面框架结构,出现如下警告:
* * * W A R N I N G * * *
NUMERICAL PROBLEMS ENCOUNTERED DURING EQUATION ASSEMBLY:
TYPELABEL DOF X-COORD Y-COORD Z-COORD PROBLEM VALUE
Joint 107 UZ 1.600000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 107 RX 1.600000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 107 RY 1.600000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 96 UZ 1.200000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 96 RX 1.200000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 96 RY 1.200000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 85 UZ 0.800000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 85 RX 0.800000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 85 RY 0.800000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 74 UZ 0.400000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 74 RX 0.400000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 74 RY 0.400000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 63 UZ .000000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 63 RX .000000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 63 RY .000000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 52 UZ -0.400000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 52 RX -0.400000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 52 RY -0.400000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 41 UZ -0.800000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 41 RX -0.800000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 41 RY -0.800000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 30 UZ -1.200000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 30 RX -1.200000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 30 RY -1.200000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 10 UZ -1.600000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 10 RX -1.600000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 10 RY -1.600000 -1.600000 3.000000 Diag = 0 --> 1.00E-10
Joint 108 UZ 1.600000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 108 RX 1.600000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 108 RY 1.600000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 97 UZ 1.200000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 97 RX 1.200000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 97 RY 1.200000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 86 UZ 0.800000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 86 RX 0.800000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 86 RY 0.800000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 75 UZ 0.400000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 75 RX 0.400000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 75 RY 0.400000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 64 UZ .000000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 64 RX .000000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 64 RY .000000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 53 UZ -0.400000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 53 RX -0.400000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 53 RY -0.400000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 42 UZ -0.800000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 42 RX -0.800000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 42 RY -0.800000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 31 UZ -1.200000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 31 RX -1.200000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 31 RY -1.200000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 12 UZ -1.600000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
Joint 12 RX -1.600000 -1.200000 3.000000 Diag = 0 --> 1.00E-10
NUMBER OF EIGENVALUES BELOW SHIFT =0
请大家帮忙!
全部回复(3 )
  • guohaifeng01
    guohaifeng01 沙发
    这种问题一般是节点脱开或结构特别不规则时的板导荷问题.
    警告:前面是节点号,中间X、Y、Z为节点坐标。一般根据节点坐标到模型中找到相应的节点进行修改!
    节点号是运行时生成的,与模型中节点号是两回事。
    Good luck!
    2006-07-14 15:32:14
  • chchh0811
    chchh0811 板凳
    俺也碰到过,哪位高手能解答?
    2006-07-07 12:40:07
结构设计软件
41.51 万条内容 · 299 人订阅
[推荐]CAD新手的练习题(一)
(以下36个图形摘自《AutoCAD2000特训教程——基础篇》。按照该书要求,36个图形必须在1小时30分钟内完成(不要求标注)。
