土木在线论坛 \ 建筑结构 \ ANSYS \ 关于pipe单元与beam单元
关于pipe单元与beam单元
发布于:2011-08-18 15:38:18 来自:建筑结构/ANSYS [复制转发]
我用beam单元时定义实常数过程中,截面总是显示实心的方钢,而不是我想要的圆钢管,在输截面参数时我确实选的圆钢管,输的钢管内外径,请问我要怎么处理这个问题?有说用pipe单元的,用pipe16代替beam4可以吗?谢谢
全部回复(6 )
  • fengzi14
    fengzi14 沙发
    PIPE16 is a uniaxial element with tension-compression, torsion, and bending capabilities. The element has six degrees of freedom at two nodes: translations in the nodal x, y, and z directions and rotations about the nodal x, y, and z axes. This element is based on the 3-D beam element (BEAM4), and includes simplifications due to its symmetry and standard pipe geometry.
    [ 本帖最后由 fengzi14 于 2011-8-22 22:29 编辑 ]
    2011-08-22 22:20:22
  • zhangqingfang1984
    我只知道pipe16就是建立在beam4的基础上的
    2011-08-22 21:54:22
ANSYS
4.39 万条内容 · 152 人订阅
急求ansys切削硅片的仿真
急求ansys切削硅片的仿真,请教各位大侠
