土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 谁知道北京建筑师群号?
谁知道北京建筑师群号?
发布于:2006-06-14 21:20:14 来自:建筑设计/公共建筑设计 [复制转发]
谁知道北京建筑师群号? 希望有人建一个,大家可以交流!我还不会建群!
全部回复(3 )
  • lulubest1
    lulubest1 沙发
    北京建筑Q群号谁知道?
    2006-08-29 12:56:29
  • lulubest1
    lulubest1 板凳
    2006-06-18 10:23:18
公共建筑设计
51.18 万条内容 · 448 人订阅
lalalast one
The failure of the theoretical approach here presented, and the knowledge already available, to influence design can be attributed to several things. One is that culture-specific design, which is a logical consequence of cultural responsiveness, is politically difficult to be advocate and to implement. Another is that while it is necessary to know what is already known, use research and know the literature, that is not sufficient. “Facts” alone are not influential. Whether they are used on how one sees things, i.e. defines the domain and the problem. This argument has recently received empirical confirmation in a study of landscape architecture students. Although they themselves had done research on the cultural characteristics of particular user groups none of that research influenced their design work supposedly based on it. Design followed traditional arbitrary, formal and “aesthetic” criteria. Thus, for design to become more culturally responsive, changes are essential in what architecture dose, what design is seen to be and what theory is understood to be. The emphasis shifts to problem understanding, clarification and definition before problem solving. There will need to be a concern with what is to be done and why (based on the best available theory and knowledge). Explicit objectives (“what”) will need to be set, their validity judged and justifies (“why”). Are the objectives valid? How do we know? How can we find out? Having accepted the validity of these objectives one then turns to how one achieves them (which currently is the major concern). Here also much more explicitness is necessary: what means are suitable? Why? How do we know? Then we ask: have we achieved our objectives? How can we find out? All these are clearly related to what I have called the public aspects of design, the framework within which individual designers work and designs occur.
