土木在线论坛 \ 环保工程 \ 规范资料 \ 哭求垃圾填埋场 英文质料
哭求垃圾填埋场 英文质料
发布于:2006-06-13 21:05:13 来自:环保工程/规范资料 [复制转发]
哭求垃圾填埋场 英文质料
需要翻译过来 3500字 中文 左右
谢了 各位
全部回复(17 )
  • crimeyang
    crimeyang 沙发
    accordance with major redox processes in these environments
    implied by hydrochemical analyses.It was found that several
    redox processes could take place simultaneously in many
    cases ( Ludvigsen,1998 ),which is consistent with
    coexistence of sulfate reducing bacteria and methanotrophic
    bacteria in groundwater samples B and C.
    A phylogenetic descri ption of dominant microbial
    populations is an important step in understanding of ecological
    processes in aquifers beneath a landfill.However,
    phylogenetic affiliation alone is not sufficient to firmly connect
    certain microbial taxa with a biochemical reaction,therefore
    we can only hypothesize about its possible biochemical role.
    On the other hand,evidences from other aspects can be used
    to support the validity of our speculations.It is reasonable
    that more sequences are related to complex compound
    degrading fermentative bacteria in the samples B and C. For
    example,2 sequences (3JL288 and 3ML292) are affiliated
    with aminobacterium colombiense,an aminoacid degrading
    obligate anaerobe.A sequence ( 3JL293) is affiliated with
    Ilyobacter polytropus,a fermentative Fusobacterium which
    specialized in the degradation of hydroaromatic compounds.
    In this study,it is significative that phylogenetic information
    showing variations of dominant microbial populations is in
    accordance with hydrochemical changes of groundwater on the
    whole.
    3  Conclusions
    The results indicated that obvious changes of dominant
    microbial populations had occurred in groundwater in
    response to leachate from Laogang Landfill.Concentration
    variations of dissolved redox relevant species suggested that
    the dominating redox process had changed from denitrification
    to methane production Psulfate reduction. The dominating
    redox process determined is accordant with the closest
    relatives of some dominant clones,based on their indications
    on the ability to perform redox reactions in the GenBank
    database.
    2006-06-14 17:45:14
  • crimeyang
    crimeyang 板凳
    respectively.From a statistical standpoint,each combined
    genotype was generally regarded as a unique population(Yu,
    2001).
    From 45,49 and 48 combined genotypes in A,B and C
    Libraries,there were 7,8 and 7 including 4 clones or more,
    which been regarded as the representatives of the dominant
    microbial populations.Inserts of one clone from each
    dominant combined genotype were successfully partially
    sequenced (≈600 bp ).Sequences were assigned to major
    microbial groups and the closest known relatives were chosen
    by searching in GenBank databases based on BLAST
    similarities.Summary of phylogenetic affiliation of the
    dominant microbial populations are shown in Table 2.
    There is strong dominance by bacteria belonging to β2
    Proteobacteria in the A library,while no clones showed
    affiliation to β2 Proteobacteria,and relatively dominant
    microbial groups are gram positive bacteria (e. g. Firmicutes,
    Fusobacteria) in the libraries B and C. The results indicated
    that there is a complete shift in the composition of the
    dominant populations after landfilling.On the other hand,
    there is no clear transition of dominant microbial populations
    found between the sample B and C.
      Based on the GenBank’s indications of the closest
    relative of a retrieved sequence , a possible biochemical role
    of the bacterium represented by the sequence could be
    surmised. It should be noted that 1 sequence related to
    genera capable of denitrification ( Azoarcus related ) were
    retrieved.Remarkably,3 sequences are closely related to
    sulfate reducers.Three sequences are associated with the
    methanotrophic bacteria though no sequence affiliated with
    methanogenic bacterium was encountered.This situation is in
    2006-06-14 17:45:14
规范资料
10.99 万条内容 · 246 人订阅
生活垃圾填埋污染控制标准
在咱这没找到,从别的地方找来的,传上来给大家共享吧!
