土木在线论坛 \ 建筑结构 \ SAP2000 \ SAP2000 15.0.0发布了
SAP2000 15.0.0发布了
发布于:2011-06-28 12:51:28 来自:建筑结构/SAP2000 [复制转发]
SAP2000 V15.0.0发布了,根据CSI官网显示,是6月15更新的,同时CSIBridge更新到了V15.1.0, PERFORM-3D 也更新到了V5.0.0。
SAP2000 V15 Enhancements Subscribe RSS
  • New graphical user interface with tabbed windows.
  • New DirectX graphics.
  • Display and output of frame stresses.
  • Load optimization feature to determine the optimal loading scale factors to achieve goals and limits on displacement and force response throughout the structure.
  • Built-in European concrete and steel material properties.
  • Canadian NBCC loading for wind, seismic, and response-spectrum.
  • American ASCE-7 loading for wind, seismic, and response-spectrum.
  • Italian NTC 2008 response-spectrum functions with geographic database.
  • Indian steel frame design code IS 800 2008.
  • New Zealand steel frame design code NZS 3404-1997.
  • Canadian steel frame design code CSA S16-2009.
  • Updated Hong Kong concrete frame design code to include Supplement 1.
  • Australian concrete frame design code AS3600-2009.
  • Enhanced Eurocode 3-2005 steel frame design, including design for Class 4 sections.
  • National annexes for Eurocode 2-2004 concrete frame design for Singapore, Germany, and Portugal.
  • National annexes for Eurocode 3-2005 steel frame design for Singapore, Germany, and Portugal.
  • Hybrid steel frame section property.
  • Simple arc for tendon profile definition.
  • Updated API functionality.
  • Import of StruCAD*3D design parameters and wave acceleration loading.
  • Note that the Bridge module has been moved to the CSiBridge product with expanded features and capabilities. Basic moving-load analysis has been retained for non-bridge applications.
  • Other minor enhancements.
  • 感兴趣的可以去官网看一下。http://www.csiberkeley.com/
SAP2000V15.0.0改进:
  • 增加窗口标签和新的图形用户界面
  • 增加新的DirectX图形
  • 显示与输出框架应力
  • 支持荷载优化功能,可以确定最佳荷载系数以实现对结构整个的位移与力响应进行限制
  • 内带欧洲混凝土和钢材的材料属性
  • 加拿大风荷载、地震作用与反应谱荷载规范:NBCC.
  • 美国风荷载、地震作用与反应谱荷载规范:ASCE-7.
  • 意大利反应谱函数与地理数据库:NTC 2008.
  • 印度钢框架结构设计规范:IS 800 2008.
  • 新西兰钢框架结构设计规范:NZS 3404-1997.
  • 加拿大钢框架结构设计规范:CSA S16-2009.
  • 更新香港混凝土框架结构设计规范,包括补充条款1
  • 澳大利亚混凝土框架结构设计规范:AS3600-2009.
  • 增强了欧洲钢结构设计规范:Eurocode 3-2005 , 包括4类截面的设计.
  • 在Eurocode 2-2004 中附带新加坡、德国、葡萄牙的混凝土框架结构设计.
  • 在Eurocode 3-2005中附带新加坡、德国、葡萄牙的钢框架结构设计.
  • 支持定义混合钢框架截面属性.
  • 支持定义弧形钢索.
  • 升级了API 功能.
  • 支持导入StruCAD*3D 设计参数与波浪加速荷载.
  • 把桥梁模块移到了CSiBridge产品,扩展了新的特色与功能.
  • 保留了非桥梁方面的的基本移动荷载分析.
  • 改进一些其他的细节.
[ 本帖最后由 kyosoki 于 2011-6-28 15:26 编辑 ]
全部回复(7 )
  • ypac
    ypac 沙发
    替大伙感谢楼主!楼主威武!
    2012-04-09 12:37:09
  • linmj10
    linmj10 板凳
    希望早日有SAP2000 15的汉化补丁。
    2011-08-15 12:04:15
SAP2000
3.12 万条内容 · 183 人订阅
关于SAP2000的三维和二维比较问题
今天简单弄了一个标准断面 先是二维进行计算 之后建三维五跨模型 为何梁板的弯矩值差异很大 三维的梁弯矩值要比二维小 而板却大 很是迷茫 请各位前辈赐教……[ 本帖最后由 r452442987 于 2011-6-27 10:37 编辑 ]
