土木在线论坛 \ 电气工程 \ 成套电气设备 \ 求电气五防英文表达方式
求电气五防英文表达方式
发布于:2011-06-10 19:35:10 来自:电气工程/成套电气设备 [复制转发]
昨天去面一家合资单位的结构设计,对方经理要求电气五防及出厂检验的程序用英文表达,-_-!
哥们 心里那是憋屈啊
全部回复(7 )
  • lanbozhou
    lanbozhou 沙发
    Thank U very very very much!
    2011-06-17 16:48:17
  • luxaq
    luxaq 板凳
    1、 prevent to operate DS on load ( DS shall not be operated during CB or LBS or contactor has been closed.)
    2、 provent to mishandle DS or LBS or contactor ( It can not be operated until operating instruction has matched with device.)
    3、 prevent to close DS or LBS during ES is closed ( Only if ES has been opened, DS or DS truck can be turn to working position,and then DS or LBS can be closed.)
    4、prevent to mishandle ES during power on( only if DS has been opened, DS or DS truck can be turn to test position, and then ES can ne closed )
    5、prevent to enter into live cubicle during power on (Only if power has been off, operator can open the door and enter into live cubicle
    不一定完全对,仅供参考
    [ 本帖最后由 luxaq 于 2011-6-17 11:45 编辑 ]
    2011-06-17 11:43:17
成套电气设备
15.97 万条内容 · 628 人订阅
中压软启动器的问题
我想问一下,ABB、施耐德、西门子这几个厂家有没有中压软启动器?
