Use shaded skylights to compensate for any resultant loss of natural daylight.
运用带有遮阳的天窗以弥补自然光的损失。
Choose and position landscape to provide adequate shade without blocking access to cooling breezes.
选择并确定地点来提供合适的遮阳,并且不会阻挡凉爽微风的进入。
Use planting instead of paving, to reduce ground temperature and the amount of reflected heat.
用绿化代替石头路面,以降低地面的温度及其反射的热量。
A ’fly roof’ can be used to shade the entire building. It protects the core building from radiant heat and allows cooling breezes to flow beneath it.
“漂浮屋顶”可以在整栋建筑上运用,达到遮阳效果。它可以保护建筑的核心部分免受热辐射,并使凉爽的微风从底下吹过。
Adjustable shading is particularly useful for eastern and western elevations, as the low angle of the sun makes it difficult to get adequate protection from fixed shading. Adjustable shading gives greater control while enabling daylight levels and views to be manipulated. Appropriate adjustable systems include sliding screens, louvre screens, shutters, retractable awnings and adjustable external blinds.
对于东西立面可调节式遮阳是非常重要的,因为太阳的入射高度角低,使固定的遮阳设备很难达到一个准确的支出角度。可调节式遮阳给与你更大的可控性,可以选择和调整太阳光的强弱和视野。适合的可调节系统包括:水平滑动屏风式,天窗式遮阳棚,曲臂遮阳棚和可调节式外遮阳百叶。
全部回复(14 )
只看楼主 我来说两句回复 举报
