土木在线论坛 \ 人才招聘 \ 学生专栏 \ 澳大利亚著名建筑师谈遮阳在建筑外立面应用(摘录)
发布于:2006-05-12 13:22:12 来自:人才招聘/学生专栏 [复制转发]
Use shaded skylights to compensate for any resultant loss of natural daylight.
运用带有遮阳的天窗以弥补自然光的损失。
Choose and position landscape to provide adequate shade without blocking access to cooling breezes.
选择并确定地点来提供合适的遮阳,并且不会阻挡凉爽微风的进入。
Use planting instead of paving, to reduce ground temperature and the amount of reflected heat.
用绿化代替石头路面,以降低地面的温度及其反射的热量。
A ’fly roof’ can be used to shade the entire building. It protects the core building from radiant heat and allows cooling breezes to flow beneath it.
“漂浮屋顶”可以在整栋建筑上运用,达到遮阳效果。它可以保护建筑的核心部分免受热辐射,并使凉爽的微风从底下吹过。
Adjustable shading is particularly useful for eastern and western elevations, as the low angle of the sun makes it difficult to get adequate protection from fixed shading. Adjustable shading gives greater control while enabling daylight levels and views to be manipulated. Appropriate adjustable systems include sliding screens, louvre screens, shutters, retractable awnings and adjustable external blinds.
对于东西立面可调节式遮阳是非常重要的,因为太阳的入射高度角低,使固定的遮阳设备很难达到一个准确的支出角度。可调节式遮阳给与你更大的可控性,可以选择和调整太阳光的强弱和视野。适合的可调节系统包括:水平滑动屏风式,天窗式遮阳棚,曲臂遮阳棚和可调节式外遮阳百叶。
全部回复(14 )
  • lu806217826
    lu806217826 沙发
    :handshake :handshake :handshake :handshake
    2009-07-30 09:13:30
  • talentzr
    talentzr 板凳
    是还不错,生态环境弄得挺好
    2006-05-12 20:48:12
学生专栏
23.9 万条内容 · 138 人订阅
请各位前辈指引~~
我是刚毕业一年的专科生~学的是建筑工程~!因一些原因我从施工单位来到了房地产公司!我现在的施工经验还不丰富,请我是不是对 以后的发展不好呢!??在房地产公司如何做才会有更好的发展啊?谢谢前辈指引!!!!!!!!
