土木在线论坛 \ 注册考试 \ 注册土木工程师 \ swedge程序说明翻译
swedge程序说明翻译
发布于:2006-05-10 11:33:10 来自:注册考试/注册土木工程师 [复制转发]
Support Tutorial
Bolts and / or shotcrete may be added to an SWEDGEmodel, to evaluate the effect of support on wedge tability.In this tutorial, we will first add bolts to a wedge model,and then shotcrete, and discuss how each is implemented in the SWEDGE analysis.Let’s start with a new (Deterministic) file for the purposes
of the following demonstration.
Select: File →New
锚杆和喷砼可能在SWEDGE模型中加入,以分析支护对块体稳定影响,这里,我们首先在模型中添加锚杆,然后是喷砼,讨论各自在模型分析中的作用,我们下来开始一个新文件以实现这一目标。
Adding Bolts
Bolts are added individually to a wedge model, with the Add Bolt option in the toolbar or the Support menu.
Select: Support →Add Bolt
在模型中,锚杆是分别加入的,使用工具条或Support菜单中的锚杆选项来实现。
1. Move the cursor into the Top or Front orthogonal views.
2. Notice that the cursor changes to an “arrow / rockbolt”icon.
3. As you move the cursor over the wedge, notice that the “rockbolt” and “arrow” now line up – this indicatesthat you may add the bolt to the wedge.
4. Click the LEFT mouse button at a point on the wedge where you want the bolt installed.
5. The bolt will initially be installed NORMAL to the face of the wedge on which you clicked (ie. normal to the Upper or Face slope), however you can modify the orientation using the Bolt Properties dialog which you will see in the middle of the screen.
1.移动光标到Top or Front视图;
2.注意光标变成一个“箭头/锚杆)图标
3.当你移动光标,“rockbolt” and “arrow”会line up,表明可以添加。
4.点击鼠标左键你想施加的点
5.锚杆将初步加在NORMAL模型表面,使用屏幕中的锚杆特性修改对话框可以修改方位。
全部回复(4 )
  • red1989
    red1989 沙发
    内容还可以,但太少了,能持续上传就好了
    2013-01-24 17:15:24
  • lhf711223
    lhf711223 板凳
    要是有完整的说明翻译就好了!:victory:
    2009-11-18 11:21:18
注册土木工程师
6.76 万条内容 · 269 人订阅
请开辟注册土木工程师(水利水电)专栏
鉴于大纲已经公布,请开辟注册土木工程师(水利水电)专栏,对大家交流有个很好的平台
