土木在线论坛 \ 环保工程 \ 水处理 \ 反渗透装置泵、阀的启动,有兴趣的来说说
反渗透装置泵、阀的启动,有兴趣的来说说
发布于:2006-05-07 20:18:07 来自:环保工程/水处理 [复制转发]
现在反渗透高压泵后都装有 慢开门,一般装置启动时都是先启高压泵,然后开 慢开门 以防止高压对膜的冲击。
如果高压泵采用变频器(或软启动器)控制,先开 泵出口阀(慢开门),这样操作会对膜有多大的冲击(伤害)?
全部回复(19 )
  • august0120
    august0120 沙发
    总结:1 高压泵在慢开阀、软起动器、变频器中选择一种即可
    2 离心泵短时不怕憋,憋的时间长了泵内水流发热,很危险。
    2006-05-17 15:19:17
  • shuimuqgh
    shuimuqgh 板凳
    憋压会造成很大的压力啊
    即使别的没关系,法兰等连接的地方时间长了也容易滋水啊
    而且如果用PVC管,那不是更危险了??
    望各位高手指教……
    2006-05-15 15:42:15
水处理
43.47 万条内容 · 1518 人订阅
The Nalco Water Handbook.
ISBN: 0070458723Author: ,Publisher: McGraw-Hill ProfessionalSummary:With the nation looking toward a goal of ``zero discharge’’ in water pollutants by the early 1980s, this timely handbook is an ideal source of information for specialists and nonspecialists alike. It provides completely practical data and techniques in the four major water conservation and use areas: (1) water chemistry, sources, and contaminants; (2) unit operations and treatment; (3) industrial and municipal use of water and its disposal; and (4) special technology in water treatment.
