土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 混凝土建筑加固英语论文
混凝土建筑加固英语论文
发布于:2011-05-24 23:33:24 来自:建筑结构/混凝土结构 [复制转发]
论文简介:
Structure in the long-term natural environment and under the use environment's function, its function is weaken inevitably gradually, our structural engineering's duty not just must finish the building earlier period the project work, but must be able the science appraisal structure damage objective law and the degree, and adopts the effective method guarantee structure the security use, that the structure reinforcement will become an important work.
附件名:20115241306251236550.zip
文件大小:59K
(升级VIP 如何赚取土木币)
全部回复(4 )
  • shangxikun
    shangxikun 沙发
    找了一天可算找到了,如果配上翻译就更好了
    2014-05-08 16:02:08
  • hanjie19901118
    恩恩,不错。。。
    2013-12-25 19:19:25
140.17 万条内容 · 2231 人订阅
混凝土结构加固论文
论文简介: Structure in the long-term natural environment and under the use environment's function, its function is weaken inevitably gradually, our structural engineering's duty not just must finish the building earlier period the project work, but must be able the science appraisal structure damage objective law and the degree, and adopts the effective method guarantee structure the security use, that the structure reinforcement will become an important work. What may foresee will be the 21st century, the human building also by the concrete structure, the steel structure, the bricking-up structure and so on primarily, the present stage I will think us in the structure reinforcement this aspect research should also take this as the main breakthrough direction.
