土木在线论坛 \ 建筑设计 \ 建筑资料库 \ 材料简介
材料简介
发布于:2011-05-16 17:19:16 来自:建筑设计/建筑资料库 [复制转发]
论文简介:
It is much easier to lay blocks and bricks with mortar joints than to cut them to fit precisely with dry joints. Today, mortar is usually made from sand, portland cement, and some additives, but, prior to the late nineteenth century, mortar usually consisted of sand and lime. Since lime is water-soluble, the mortar joints were a common source of weakness in stone and brick structures. Gypsum was used as mortar in Egypt, and naturally occurring bitumen in Mesopotamia.
附件名:20115161305537589263.zip
文件大小:281K
(升级VIP 如何赚取土木币)
  • keithcarmen
    keithcarmen 沙发
    搂主的帖子不错,我正需要!
    2011-05-17 17:48:17
  • keithcarmen
    keithcarmen 板凳
    搂主的帖子不错,我正需要!
    2011-05-17 17:48:17
建筑资料库
13.61 万条内容 · 216 人订阅
材料简介
论文简介: Portland cement was developed in the nineteenth century, which has become one of the most important building materials. It has complex chemical compositions, but the main cementing compound is calcium silicate hydrate. Ordinary Portland Cement can be modified for high strength in early period, for sulfate resistance, low heat production, or use in masonry. For architectural use, it can be produced in white, black,
