土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 求助CAD2006安装问题。急救中
求助CAD2006安装问题。急救中
发布于:2006-04-30 08:43:30 来自:建筑设计/CAD下载及教程 [复制转发]
刚刚恢复的系统无法安装06了 这是log信息
[4/30/2006 08:26:44] === Installation started on QQQ by mnbx ===
[4/30/2006 08:26:47] [Info] Windows Installer upgrade is not required
[4/30/2006 08:26:47] System Version = 3.0.3790.2180
[4/30/2006 08:26:47] Installation skipped: MSI Runtime 3.0
[4/30/2006 08:26:47] [Info] .NET Framework Runtime upgrade is not required
[4/30/2006 08:26:47] System Version = 1.1.4322.2032
[4/30/2006 08:26:47] Installation skipped: .NET Framework Runtime 1.1
[4/30/2006 08:26:47] Installation started: .NET Framework Runtime 1.1 Language Pack
[4/30/2006 08:26:47] Command = "F:softCADAuto CAD2006BinAcadFEUIsupportdotnetfxchslangpack.exe" /q:a /c:"inst /qb"
[4/30/2006 08:26:49] Installation succeeded: .NET Framework Runtime 1.1 Language Pack
[4/30/2006 08:26:49] [Info] .NET Framework Runtime upgrade is not required
[4/30/2006 08:26:49] System Version = 1.1.4322.2032
[4/30/2006 08:26:51] Installation skipped: .NET Framework Runtime 1.1 SP1
[4/30/2006 08:26:51] [Info] MDAC upgrade is not required
[4/30/2006 08:26:51] System Version = 2.81.1117.0
[4/30/2006 08:26:51] Installation skipped: MDAC 2.7
[4/30/2006 08:26:51] Installation started: Autodesk DWF Viewer
[4/30/2006 08:26:51] Command = "F:softCADAuto CAD2006BinAcadFEUIsupportaevDWFViewerSetup.exe" /u2 /q2
[4/30/2006 08:26:52] [Error: 11] 试图加载格式不正确的程序。
[4/30/2006 08:26:52] Installation failed: Autodesk DWF Viewer
[4/30/2006 08:26:52] [Info] Failure is ignored
[4/30/2006 08:26:52] Installation started: Flash
[4/30/2006 08:26:52] Command = "F:softCADAuto CAD2006BinAcadFEUIsupportflashSilent Install Flash Player 7 AX.exe" /q
[4/30/2006 08:26:53] [Error: 1] 函数不正确。
[4/30/2006 08:26:53] Installation failed: Flash
[4/30/2006 08:26:53] [Info] Failure is ignored
[4/30/2006 08:26:53] Installation started: AutoCAD 2006
[4/30/2006 08:26:53] Command = msiexec /i "F:softCADAuto CAD2006BinAcadFEUIacad.msi" /L*v C:DOCUME~1mnbxLOCALS~1TempAcadInstall.log
[4/30/2006 08:33:01] [Error: 1603] 安装时发生严重错误
[4/30/2006 08:33:01] Installation failed: AutoCAD 2006
[4/30/2006 08:33:01] Installation aborted
[4/30/2006 08:33:04] === Installation ended ===
全部回复(3 )
  • mn_bx
    mn_bx 沙发
    不好意思过了很久才来。。
    等了这么久。偶把系统重新安装 了
    2006-05-17 10:16:17
  • songweifeng85
    songweifeng85 板凳
    你先把microsoft office 卸载了,然后再装autoCAD,问题就可以解决了
    最后,再把microsoft office 装上就可以了
    2006-04-30 22:03:30
CAD下载及教程
52.09 万条内容 · 690 人订阅
怎么才能把修改块呢?
各位师兄师姐,我画CAD 的时候从下载的图库里面调出的图都是不能修改的,怎么办呀?例如:我的柱子是3.6米的,可图库里的是3.0米。我不知道怎么才能修改到3.6米。谢谢了
