土木在线论坛 \ 建筑结构 \ 结构资料库 \ What is a Poor Quality Strong-Motion Record
发布于:2011-05-05 20:55:05 来自:建筑结构/结构资料库 [复制转发]
Abstract. Some accelerograms are affected by non-standard recording and digitization problems
that mean they are often not used in strong-motion studies. These non-standard problems cannot
be corrected by the standard processing techniques that remove low and high-frequency noise from
the time-history. Records from analogue instruments are more prone to these problems but even
records from digital instruments, which are becoming increasingly common, can be affected by
such errors. Since all strong-motion data is valuable it is important to know whether any useful
information can be obtained from accelerograms that are affected by such problems. This article
examines whether strong-motion records from analogue instruments that are missing their initial part
due to late triggering of the instrument and also strong-motion records from digital instruments with
low A/D converter resolution can be used for response spectral studies. It is found, by simulating such
errors on high-quality strong-motion records, that good response spectral ordinates can be obtained
from such ‘poor-quality’ records within the period range of most engineering interest
结构资料库
41.29 万条内容 · 428 人订阅
Earthquake Damage Scenarios of the Building
Abstract. Damage scenarios relevant to the building stock of the town of Potenza, Southern Italy,are presented. A procedure for the preparation of scenarios has been purposely set up. In the firststep, the inventory of the building stock has been made. Location and characteristics of buildings
