土木在线论坛 \ 电气工程 \ 电站工程 \ 英文不好,有点迷糊,求助!!
英文不好,有点迷糊,求助!!
发布于:2006-04-21 15:32:21 来自:电气工程/电站工程 [复制转发]
Current sense transformer ratio 1:500 Have to able to sense currents under normal conditions that means max. 500A. Under this max. requirements the current sense transformer must give correct signals. The burden that is used at the end of the current sense transformer is 18 Ohm. The current sense transformer case dimensions are nearly l*b*h of 49,5mm*49,5mm*27,5mm. The sense hole is nearly 19mm. The output of the transformer is with two fast terminal with 6,3mm*0,8mm and nearly 32mm centre to centre between each terminal. This CT have 500 windings with 0,40mm wire to a nearly OD*ID*HT (40mm*30mm*16mm) silicon steel core.
全部回复(6 )
  • jhongsong123
    jhongsong123 沙发
    基本没问题,可以得85分
    2006-05-06 16:00:06
  • colourcat_3392
    哈哈,楼主不会整段都有问题吧,里面哪些句有问题?
    2006-05-06 09:33:06
电站工程
5.34 万条内容 · 273 人订阅
被淘汰的电度表型号有那些呢
被淘汰的电度表型号有那些呢
