土木在线论坛 \ 电气工程 \ 成套电气设备 \ 英文不好,有点迷糊,求助!!!
英文不好,有点迷糊,求助!!!
发布于:2006-04-21 15:31:21 来自:电气工程/成套电气设备 [复制转发]
Current sense transformer ratio 1:500 Have to able to sense currents under normal conditions that means max. 500A. Under this max. requirements the current sense transformer must give correct signals. The burden that is used at the end of the current sense transformer is 18 Ohm. The current sense transformer case dimensions are nearly l*b*h of 49,5mm*49,5mm*27,5mm. The sense hole is nearly 19mm. The output of the transformer is with two fast terminal with 6,3mm*0,8mm and nearly 32mm centre to centre between each terminal. This CT have 500 windings with 0,40mm wire to a nearly OD*ID*HT (40mm*30mm*16mm) silicon steel core.
Current sense transformer ratio 1:1000 Have to able to sense currents under normal conditions that means max. 1.000A. Under this max. requirements the current sense transformer must give correct signals. The burden that is used at the end of the current sense transformer is 2,2 Ohm. The current sense trasformer case dimensions are nearly l*b*h of 36mm*36mm (top rounded)*15,6mm. The sense hole is nearly is nearly 12,8mm. The output is with two 0,8mm pins and between the pins the distance is 24mm centre to centre. There are a third pin exists for strength. This CT have 1.000 windings with 0,224mm wire ta a nearly OD*ID*HT (30mm*20mm*10mm) silicon steel core.
全部回复(15 )
  • 互感器
    互感器 沙发
    CTransf1_1000
    2006-04-25 14:04:25
  • 互感器
    互感器 板凳
    CTransf1_500
    2006-04-25 14:04:25
成套电气设备
15.97 万条内容 · 628 人订阅
低压总柜一般都装避雷器吗?
低压进线总柜一般都装避雷器或浪涌保护器吗?比方说GCS柜,GGD柜,等等我看到过GCS有装的,GGD柜又没有装,不知道为什么?
