土木在线论坛 \ 给排水工程 \ 天正给排水 \ 特性窗口是个BUG么?【twt8.2】
特性窗口是个BUG么?【twt8.2】
发布于:2011-04-06 16:38:06 来自:给排水工程/天正给排水 [复制转发]
画了一条管,选中,ctrl+1调出特性窗口,结果特性窗口显示无选择,其他天正给排水对象也是,选中的情况下,特性窗口均显示无选择,
这是个BUG么?
全部回复(6 )
  • 慢慢记住我
    楼上的中文不怎么样啊?中文表达不清楚这意思么?
    2011-08-30 17:26:30
  • profer
    profer 板凳
    QAFLAGS=0就可以了
    * What is QAFLAGS?
    QAFLAGS been used a long time (< r12) by developers and autodesk themself too.
    QAFLAGS acceps a value between 0 and 32767
    bit 0 (1) : ^C in menu macro cancels grips (acts like keyboard ).
    bit 1 (2) : no pause during text screen listings.
    bit 2 (4) : no "alert" dialogs (text display instead).
    bit 7 (128) : accepts "screen picks" (point lists) via (command) function.
    Normally QAFLAGS should be set to 0. Because it might be set to other values it is a good idea to put (setvar "QAFLAGS" 0) in acaddoc.lsp or any other of your lisp files that you use for startup.
    2011-08-30 16:46:30
天正给排水
6.48 万条内容 · 366 人订阅
版主们进来,希望天正增加个方便的把建筑底图全部变灰的功能。
现在很多人都习惯把建筑底图变灰,然后在上面画图,所以希望天正增加这个功能,
