土木在线论坛 \ 人才招聘 \ 学生专栏 \ 结构工程常用词汇
结构工程常用词汇
发布于:2011-04-06 00:51:06 来自:人才招聘/学生专栏 [复制转发]
混凝土:concrete
钢筋:reinforcing steel bar
钢筋混凝土:reinforced concrete(RC)
钢筋混凝土结构:reinforced concrete structure
板式楼梯:cranked slab stairs
刚度:rigidity
徐变:creep
水泥:cement
钢筋保护层:cover to reinforcement
梁:beam
柱:column
板:slab
剪力墙:shear wall
基础:foundation
剪力:shear
剪切变形:shear deformation
剪切模量:shear modulus
拉力:tension
压力:pressure
延伸率:percentage of elongation
位移:displacement
应力:stress
应变:strain
应力集中:concentration of stresses
应力松弛:stress relaxation
应力图:stress diagram
应力应变曲线:stress-strain curve
应力状态:state of stress
钢丝:steel wire
箍筋:hoop reinforcement
箍筋间距:stirrup spacing
加载:loading
抗压强度:compressive strength
抗弯强度:bending strength
抗扭强度:torsional strength
抗拉强度:tensile strength
裂缝:crack
屈服:yield
屈服点:yield point
屈服荷载:yield load
屈服极限:limit of yielding
屈服强度:yield strength
屈服强度下限:lower limit of yield
荷载:load
横截面:cross section
承载力:bearing capacity
承重结构:bearing structure
弹性模量:elastic modulus
预应力钢筋混凝土:prestressed reinforced concrete
预应力钢筋:prestressed reinforcement
预应力损失:loss of prestress
预制板:precast slab
现浇钢筋混凝土结构:cast-in-place reinforced concrete
双向配筋:two-way reinforcement
主梁:main beam
次梁:secondary beam
弯矩:moment
悬臂梁:cantilever beam
延性:ductileity
受弯构件:member in bending
受拉区:tensile region
受压区:compressive region
塑性:plasticity
轴向压力:axial pressure
轴向拉力:axial tension
吊车梁:crane beam
可靠性:reliability
粘结力:cohesive force
外力:external force
弯起钢筋:bent-up bar
弯曲破坏:bending failure
屋架:roof truss
素混凝土:non-reinforced concrete
无梁楼盖:flat slab
配筋率:reinforcement ratio
配箍率:stirrup ratio
泊松比:Poisson’s ratio
偏心受拉:eccentric tension
偏心受压:eccentric compression
偏心距:eccentric distance
疲劳强度:fatigue strength
偏心荷载:eccentric load
跨度:span
跨高比:span-to-depth ratio
跨中荷载:midspan load
框架结构:frame structure
集中荷载:concentrated load
分布荷载:distribution load
分布钢筋:distribution steel
挠度:deflection
设计荷载:design load
设计强度:design strength
构造:construction
简支梁:simple beam
截面面积:area of section
浇注:pouring
浇注混凝土:concreting
钢筋搭接:bar splicing
刚架:rigid frame
脆性:brittleness
脆性破坏:brittle failure
学生专栏
23.9 万条内容 · 138 人订阅
二级注册结构工程师教辅推荐
  1.《二级注册结构工程师专业考试过关必做600题(含历年真题)》,中国石化出版社  2.《一、二级注册结构工程师必备规范汇编(修订缩印本)》,中国建筑工业出版社  3.《全国二级注册结构工程师专业考试模拟题及详解》,机械工业出版社
