土木在线论坛 \ 水利工程 \ 水利软件 \ 200种数据恢复的方法
200种数据恢复的方法
发布于:2006-04-12 16:54:12 来自:水利工程/水利软件 [复制转发]
E文版的。
200 ways to revive a hard drive
We based one of our most popular pop quiz challenges on a situation every tech support person has faced or will face at least once: a failed hard drive. In that particular case, a Compaq Prolinea 4/66 user was getting errors like "disk 0 error" and "invalid drive specification." Here were the other facts in the case:
• The data wasn’t backed up.
• The problem came out of nowhere.
• The user had accessed Setup and tried to manually enter the settings for the drive type when "Auto" didn’t work.
• There was no startup disk made by this machine.
Reviving a drive like that one—even if only long enough to copy its data before you throw the drive in the garbage—is a tough challenge. When I asked TechRepublic members how they would troubleshoot a situation like this one, we received over 200 solutions, and we heard from a number of TechRepublic members who wanted to know “what everybody else suggested.” So we decided to publish this collection of over 200 ways to revive a hard drive.
In editing this document, we tried as much as possible to preserve the voices of the TechRepublic members who submitted these solutions. Of course, as the legal blurb at the end of the document declares, we can’t promise that any of these tips will work in every setting. But we thought you’d enjoy reading what your fellow IT professionals had to say on this subject. Enjoy!
全部回复(3 )
  • 水锤
    水锤 沙发
    英语水平太差
    2007-09-15 15:02:15
  • xurongdong
    xurongdong 板凳
    200种数据恢复的方法,英文版的,好东西,谢谢楼主!!
    2007-09-14 18:36:14
水利软件
13.32 万条内容 · 207 人订阅
解决Windows XP关机却重启的故障
  对于Windows XP来说,由于其采用了安全性能较高的NT内核,系统运行还算稳定,除了关机速度较慢之外,一般情况下很少发生关机故障。但有时在关闭Windows XP时却莫名其妙地重启,该故障是Windows XP操作系统关机故障中最容易出现的故障。造成该故障的原因可能有以下几方面原因:  系统设置  Windows XP默认情况下,当系统出现错误时会自动重新启动,这样当用户关机时,如果关机过程中系统出现错误就会重新启动计算机。将该功能关闭往往可以解决自动重启的故障。
