土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 一个相当好的CAD命令总结
一个相当好的CAD命令总结
发布于:2006-04-09 18:22:09 来自:建筑设计/CAD下载及教程 [复制转发]
相当不错!!!
看了就知道
全部回复(11 )
  • ladawjl
    ladawjl 沙发
    3A, *3DARRAY
    3DO, *3DORBIT
    3F, *3DFACE
    3P, *3DPOLY
    AR, *ARC
    ADC, *ADCENTER
    SS, *AREA
    AL, *ALIGN
    AP, *APPLOAD
    A, *ARRAY
    ATT, *ATTDEF
    -ATT, *-ATTDEF
    ATE, *ATTEDIT
    -ATE, *-ATTEDIT
    ATTE, *-ATTEDIT
    BL, *BLOCK
    -B, *-BLOCK
    BH, *BHATCH
    BO, *BOUNDARY
    -BO, *-BOUNDARY
    B, *BREAK
    C, *COPY
    CC, *CIRCLE
    CH, *PROPERTIES
    CG, *CHANGE
    -CH, *CHANGE
    CF, *CHAMFER
    CN, *CONFIG
    COL, *COLOR
    COLOUR, *COLOR
    DI, *DIMSTYLE
    dde, *DIMALIGNED
    DA, *DIMANGULAR
    DBA, *DIMBASELINE
    DBC, *DBCONNECT
    DCE, *DIMCENTER
    DC, *DIMCONTINUE
    DD, *DIST
    DE, *DDEDIT
    DDI, *DIMDIAMETER
    DED, *DIMEDIT
    DIV, *DIVIDE
    D, *DIMLINEAR
    DO, *DONUT
    DDR, *DIMORDINATE
    FF, *OPEN
    DOV, *DIMOVERRIDE
    DR, *DRAWORDER
    DR, *DIMRADIUS
    DS, *DSETTINGS
    DST, *DIMSTYLE
    DT, *DTEXT
    DV, *DVIEW
    E, *ERASE
    EL, *ELLIPSE
    EXIT, *QUIT
    EXP, *EXPORT
    EXT, *EXTRUDE
    F, *FILLET
    FI, *FILTER
    G, *GROUP
    -G, *-GROUP
    GR, *DDGRIPS
    H, *BHATCH
    -H, *HATCH
    HE, *HATCHEDIT
    HI, *HIDE
    I, *INSERT
    -I, *-INSERT
    IAD, *IMAGEADJUST
    IAT, *IMAGEATTACH
    ICL, *IMAGECLIP
    IM, *IMAGE
    -IM, *-IMAGE
    IMP, *IMPORT
    IN, *INTERSECT
    INF, *INTERFERE
    IO, *INSERTOBJ
    L, *LINE
    W, *LINE
    LA, *LAYER
    -LA, *-LAYER
    www, *QLEADER
    LEN, *LENGTHEN
    LINEWEIGHT, *LWEIGHT
    LO, *-LAYOUT
    ST, *LIST
    LT, *LINETYPE
    -LT, *-LINETYPE
    LTYPE, *LINETYPE
    -LTYPE, *-LINETYPE
    LTS, *LTSCALE
    LW, *LWEIGHT
    M, *MOVE
    V, *MOVE
    ww, *MATCHPROP
    ME, *MEASURE
    MR, *MIRROR
    ML, *MLINE
    MO, *PROPERTIES
    MS, *MSPACE
    VT, *MTEXT
    MV, *MVIEW
    O, *OFFSET
    FS, *OFFSET
    OP, *OPEN
    ORBIT, *3DORBIT
    OS, *OSNAP
    -OS, *-OSNAP
    P, *PAN
    -P, *-PAN
    PA, *PASTESPEC
    PARTIALOPEN, *-PARTIALOPEN
    ED, *PEDIT
    PO, *POINT
    POL, *POLYGON
    PR, *OPTIONS
    PRCLOSE, *PROPERTIESCLOSE
    PROPS, *PROPERTIES
    bre, *PREVIEW
    PRINT, *PLOT
    PS, *PSPACE
    PU, *PURGE
    Q, *QSAVE
    QD, *QDIM
    R, *REDRAW
    RA, *REDRAWALL
    RE, *MIRROR
    RG, *REGEN
    REA, *REGENALL
    fx, *RECTANGLE
    REG, *REGION
    REN, *RENAME
    -REN, *-RENAME
    REV, *REVOLVE
    RM, *DDRMODES
    RT, *ROTATE
    RPR, *RPREF
    SA, *SAVE
    S, *STRETCH
    SC, *SCALE
    SCR, *SCRIPT
    SE, *SELECT
    SEC, *SECTION
    SET, *SETVAR
    SHA, *SHADE
    SL, *SELECT
    ss, *SNAP
    SO, *SOLID
    SP, *SPELL
    sf, *SPLINE
    SPE, *SPLINEDIT
    ST, *LIST
    SU, *SUBTRACT
    -T, *-MTEXT
    TA, *TABLET
    TH, *THICKNESS
    TI, *TILEMODE
    TO, *TOOLBAR
    TOL, *TOLERANCE
    TOR, *TORUS
    T, *TRIM
    ER, *UCS
    UCP, *DDUCSP
    UN, *UNITS
    -UN, *-UNITS
    UNI, *UNION
    VI, *VIEW
    -V, *-VIEW
    VP, *DDVPOINT
    VV, *PAN
    -VP, *VPOINT
    WB, *WBLOCK
    -W, *-WBLOCK
    只修改前面相对应的命令
    2006-05-11 16:39:11
  • ladawjl
    ladawjl 板凳
    我说的这个只能在2004以上的CAD版本才可以的 2000以及2002我就不知道了还是看上面那个吧
    2006-05-11 16:35:11
CAD下载及教程
52.09 万条内容 · 690 人订阅
请教钢梯螺旋线画法
在设计一个钢旋梯,但扶手的螺旋线怎么画。请那位高手指点一下。
