土木在线论坛 \ 建筑设计 \ 建筑资料库 \ 软土非单调压缩固结试验
软土非单调压缩固结试验
发布于:2011-03-21 18:29:21 来自:建筑设计/建筑资料库 [复制转发]
在实际岩土工程中,经常会遇到软土地基受非单调增加的荷载作用而发生的非单调压缩固结问题。虽然固结理论经过八十多余年的发展已经取得了长足的进步,但在分析这类问题时还是将加荷、卸荷过程中土体的压缩性参数视为同一常数,与实际情况并不相符。本文通过室内试验和理论分析,对软土的一维非单调压缩固结理论开展了较系统深入的研究。主要工作和研究成果如下: 1.研究了GDS先进固结试验系统的功能和特点,编制了能快速处理实验数据的程序GDSDA,并利用GDS先进固结试验系统对13组萧山饱和软土试样进行了一维压缩和渗透试验,较全面地研究了萧山软土的常规压缩和渗透特性,获得了萧山软土渗透系数k v,随有效应力p的变化规律,即:log k v-log p和e-log 10 k v均呈线性关系。 2.通过利用GDS先进固结试验系统对3组土样进行加荷-卸荷-再加荷压缩固结和渗透交叉试验以及对9组土样进行循环加载试验,进一步研究了萧山软土的非单调压缩和渗透特性,获得了在加、卸荷状态下的土性参数。试验结果表明:在非单调压缩条件下,萧山软土的e-log 10 p和e-log 10 k v的线性关系仍成立,但直线的斜率因土体所处加、卸荷状态不同而改变。 3.建立了能考虑土体在固结过程中压缩与回弹特性不同的一维非单调压缩条件下的线性固结模型,运用半解析法进行了求解,编制了相应程序,并对循环荷载下单层地基的一维非单调压缩线性固结性状进行了详细分析。结果表明:影响单层地基在循环荷载作用下固结性状的主要因素是循环荷载系数T v0,α,β,以及回弹压缩系数与压缩系数的比值α e/α v;考虑土体在固结过程中压缩与回弹特性不同时软土的固结比常规理论更快;比值α e/α v越小,固结发展越快。 4.基于e-log 10 p和e-log 10 k v线性关系,进一步建立了一维非单调压缩条件下的非线性固结模型,编制了基于半解析法的计算程序,并利用该程序较深入地分析了循环荷载下单层软土地基一维非单调压缩非线性固结性状。结果表明:除循环荷载系数T v0,α,
活动房
In the practical project of geotechnical engineering, the non-monotonic consolidation problems of soil are often encountered when subsoil is subjected to a non-monotonic increasing loading. Though the consolidation theory has been developed for eighty years and made a great achievement in the theoretical field, the compressibility of subsoil is still just taken as a constant in the process of loading, unloading and reloading, which is not consistent with the truth of practical engineering. In this dissertation, the one-dimensional consolidation theory involved with non-monotonic compression is studied systemically through laboratory testing and theoretical investigation. The main original work and results are as follows:1. The functions and features of GDS advanced consolidation testing system (GDSACTS) are investigated, and a program GDSDA is developed for test data fast processing. One-dimensional consolidation and permeability tests are conducted with 13 groups of Xiaoshan clay by GDSACTS to investigate its compressibility and permeability. It shows that both e - log 10 p and e - log 10 k v relationships are linear.2. The compression test of loading-unloading-reloading combined with permeability test as well as the ones under cyclic loading are respectively made with 3 groups and 9 groups of Xiaoshan clay samples by GDSACTS, and the behavior of compression and permeability under non-monotonic compression is studied and the relevant geotechnical parameters representing the property of the clay in the process of loading and unloading are obtained. The test results show that, under the condition of non-monotonic compression, the linear relationships of e-log 10 p and e-log 10 k v are also true, but their slopes are different with loading or unloading.3. Considering the variable compression coefficient under loading and unloading, a one-dimensional linear consolidation model is established and solved by semi-analytical method. The corresponding computer program is developed to analyze the behavior of one-dimensional consolidation of soft soil under non-monotonic compression in detail. The
建筑资料库
13.61 万条内容 · 216 人订阅
输送管道泄漏智能诊断
对于管道运输的经济安全运行、防范损失以及环境保护,流体输送管道安全监控是一项极为重要的任务。在管道系统的整体监控当中,泄漏检测与定位尤其占据着重要的地位。因而深入研究流体输送管道泄漏的智能诊断与定位方法,不但具有重要的理论意义,而且也具有巨大的实际应用价值。目前,管道泄漏检测定位技术的研究已引起了广泛关注,已经成为管道安全监控领域的热门研究课题之一。 本文系统地研究了流体输送管道的泄漏智能诊断与定位方法,主要研究工作如下: 1 针对具有先验知识的一般非线性系统,提出了一种新型的基于ANFIS非线性观测器的连续小波变换故障检测方法。首先利用系统输入—输出数据设计非线性系统的ANFIS输出观测器,然后根据实际系统与观测器输出设计出了残差产生器。利用小波变换分析残差,判断被监测系统是否发生故障。所设计的非线性观测器具有通用逼近性能,同时克服了现有方法中对噪声干扰信号突变特征点不易辨识的难点。该方法的适用对象范围相对较大。 2 为满足实时性需要,研究了基于负压波法的管道泄漏智能诊断与定位方法。提出了一种基于管道运行工况模式识别方法的泄漏实时检测策略。保证管道运行工况平稳,给出了执行器故障时容错控制器的设计方法。为提取真实信号,采用小波变换方法来消除采样噪声。为实现快速定位,采用负压波方法进行泄漏点定位。这一方法既获得了检测的实时性,又保证了定位的准确性,该方法同时也具有较高的灵敏度和稳健性。 3 如何提高泄漏定位精度一直是管道安全监控领域中热门的研究课题。为此,提出了一种基于双传感器压力梯度的管道泄漏定位方法,该方法克服了假设管道泄漏前后流体的摩擦阻力系数为常数的局限。对于难以建立精确动态数学模型的输油管道系统,这一方法仍然可以提高泄漏点的定位精度。通过与相关参考文献的比较,表明所提出的方法具有更好的优越性。 4 当前关于流体输送管道泄漏智能诊断与定位的研究大多使用单一方法,而采用多方法融合的策略进行研究却鲜有提及。受到多方法结合思路的启迪,我们提出了一种能够迅速、准确实现检测与定位的方法,即模糊决策管道泄漏诊断与定位方法。该方法利用模糊自适应推理,对于输油管道的各种不同程度的泄漏
