土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 求cad英转中字体
求cad英转中字体
发布于:2006-04-07 07:20:07 来自:建筑设计/CAD下载及教程 [复制转发]
求cad英转中字体
  • qq4839217
    qq4839217 沙发
    2008-04-23 07:32:23
  • qq4839217
    qq4839217 板凳
    THIS AGREEMENT, made and entered into on
    by and between the above named Client and the undersigned, an independently owned and operated Franchisee of Pillar To Post
    Inc., hereafter referred to as "Inspector". Inspector will conduct a visual inspection of the Property only. The inspection is
    performed in accordance with the Standards of Practice of the American Society of Home Inspectors (ASHI®) and in
    accordance with any applicable State or Provincial specific standards. This is not a Building Code inspection, title examination,
    nor a By-law compliance inspection. The Inspector does not offer an opinion as to the advisability or inadvisability of the purchase
    of the property, its value or its potential use. The inspection fee is based on a single visit to the property; additional fees may be
    charged for any subsequent visits required by the Client. If the Inspector is called upon to prepare for litigation or give testimony
    as a result of the inspection, additional fees shall be charged at the Inspector’s then current hourly rate for any time spent,
    including, but not limited to, research, consultation, additional inspection time, preparation of reports, travel, time waiting to testify,
    and court appearances.
    2. The Client will receive a written report of Inspector’s observations of the accessible features of the Property. Subject to the
    2008-04-23 07:31:23
CAD下载及教程
52.09 万条内容 · 690 人订阅
请教CAD高手,我遇到麻烦了!
我打开CAD图纸时,出现乱码:D:\AutoCAD 2004(破解版)\fonts\bigfont.shx 是大字体文件,不是常规字体文件。正在用 [simplex.shx] 替换 [bigfont]。正在重生成模型。AutoCAD 菜单实用程序已加载。命令: 指定对角点:我重新下载了bigfont.shx 字体,结果还是不行,打开就是乱码。请高手指点!
