土木在线论坛 \ 建筑设计 \ 建筑资料库 \ 路堤荷载下沉管灌注筒桩复合地基性状
路堤荷载下沉管灌注筒桩复合地基性状
发布于:2011-03-16 15:58:16 来自:建筑设计/建筑资料库 [复制转发]
随着我国经济建设的快速发展,在深厚软土地基上修建高等级公路越来越多,沉管灌注筒桩(简称筒桩)作为软土路基处理的一种新型技术,吸收了预应力管桩、振动沉管桩的技术优点,具有混凝土使用方量少,造价低,承载力高,施工方便的特性,在路堤下软土地基处理中具有广泛的应用前景。为此本文开展了对筒桩及路堤下筒桩复合地基的理论研究。 首先对筒桩进行简单的介绍,并对目前桩基及复合地基理论进行概况分析。 其次,介绍筒桩桥头软土处理的现场试验并对测试成果进行分析,包括成桩质量、单桩及群桩承载力试验、成桩前后地基土性的改变、桩问土和桩顶土压力、分层沉降、侧向位移和孔隙水压观测。分析结果表明筒桩施工工艺成熟,施工质量可靠,筒桩联合土工格栅处理桥台软基,可以很好的解决桥台的跳车问题。 第三,考虑桩土界面的摩擦接触,采用轴对称平面有限元方法对竖向荷载作用下筒桩单桩进行数值模拟,分析筒桩内、外侧摩阻力、桩端阻力及各项荷载分担比的变化规律和土塞的性状,提出筒桩单桩极限承载力的计算公式。 第四,采用典型段三维有限元方法模拟路堤下筒桩复合地基,并且考虑桩土界面的摩擦接触、挚层中的土工格栅以及填土的分层加载,以使计算模型在力学概念上更为合理,对复合地基变形、荷载传递机理的影响因素做了研究。计算表明路堤填土中的土拱效应、土工格栅的拉膜效应或多层格栅垫层的梁效应保证了大部分荷载由筒桩承担,有效的减少了复合地基总沉降和不均匀沉降。 第五,将现场实测成果与本文的有限元方法进行对比分析,表明有限元方法对筒桩单桩及路堤下筒桩复合地基的工作性状分析是可行的。
活动房
With the fast development of the national economy, more and more highway is constructed on thick soft clay ground. As a new foundation treatment technique, driven cast-in-place tubular pile (DCTP) combine both advantages of pre-stressed tubular pile and buffeting-sunk pile, and have the properties of less concrete quantity, low cost, high bearing capacity and suitable for construction. Therefore, it has a good application perspective in soft clay ground treatment. Theoretical study of the DCTP and the DCTP composite foundation below the embankment is carried out in this thesis.First, DCTP is introduced briefly. A general analysis of the current pile foundation and composite foundation theory is followed.Secondly, in-situ experimentation of DCTP soft clay treatment located in bridgehead is introduced. Results obtained are analyzed, specifically include: pile quality, test of the bearing capacity of single-pile and multi-piles, variation of ground property before and after pile construction, top and pile-to-pile soil pressure, delamination settlement, horizontal displacement and pore water pressure observation. Results show that craftwork for DCTP is applicable, and construction quality is tenable. In addition, it is found that DCTP combining the geogrid to perform bridgehead soft ground treatment is able to solve the car-jump problem.Thirdly, pile-ground interface friction touch is considered. Axis-symmetrical in-plane finite element method is used to perform numerical simulation of single DCTP under vertical loading. The inner and outer friction forces of DCTP, pile-end resistance force and variation of loading share ratio and performance of soil plug are analyzed. A formulation to perform computation of single pile utmost bearing capacity is proposed.Fourthly, DCTP composite foundation is simulated using typical three-dimensional finite element model. Pile-ground interface friction touch, geogrid of underlayer and layered loading of earthfilling is considered, so that the computational model is morerational. The deformation of composite foundation and the basic principle of influential factors on the load transformation are also studied. It is found that most part of the load is undertaken by the pile due to the soil arching effect in embankment soil, tensioned membrane effect in geogrid or beam effect in multi-layer grid underlayer. Thus, the total settlement and uneven settlement of the composite foundation is reduced effectively.Lastly, the numerical results obtained by finite element analysis are compared with those obtained by in-situ experimentation. Results show that performance analysis of the single DCTP and under embankment DCTP composite foundation using finite element method is applicable.
  • ffdpm
    ffdpm 沙发
    好好学习学习
    2011-10-30 11:21:30
建筑资料库
13.61 万条内容 · 216 人订阅
城市生活垃圾的压缩性
城市生活垃圾是人们在日常生活中或为城市日常生活提供服务的活动中产生的固体废物。近几年来,城市生活垃圾的处理一直是环境岩土工程的热门课题。国外自60年代就已开始研究城市生活垃圾的填埋课题,我国自90年代中期开始用岩土工程的方法研究生活垃圾的填埋问题。 本文首先采用国内传统的土工仪器,研究了城市生活垃圾填埋场中生活垃圾的基本土工参数如天然密度、比重、含水量、孔隙比、有机物含量、内聚力、内摩擦角及其分布规律。研究表明:天然密度大多分布在0.9-1.2t/m3之间;含水量的变化范围较大,一般分布在40%-100%之间;比重的大小与生活垃圾中有机物的含量有关,大多分布在2.0-2.4之间:有机物含量大多分布在20%-40%之间;孔隙比与深度的关系为一条直线,根据天然密度与深度的相关关系,得到了现场生活垃圾的孔隙比与自重应力的关系曲线,从而得到了现场生活垃圾的压缩系数及压缩模量的变化范围;生活垃圾的小试样三轴不固结不排水及固结不排水试验结果表明,生活垃圾的应力-应变曲线可以近似为双曲线。 然后本文研制了城市生活垃圾专用压缩仪器(BHMSW-2035型),该仪器最大行程30cm,最大承受1600kPa的压力,压缩筒高度为35cm,内直径19cm,筒的周围加二道钢箍,筒的底部设有4个排水孔,可以排出垃圾的渗滤水。采用该仪器,研究了垃圾的压缩性及其压缩规律性。单级恒定荷载的长期试验结果表明:24h前,压缩速率变化较大,24h后,压缩曲线趋于平缓;24h的压缩量约占90天总压缩量的90%。试验研究还表明:压缩时间和压缩应变的比值与压缩时间的关系为一条直线,因此,生活垃圾的压缩应变与压缩时间的关系符合双曲线函数。当压缩时间趋于无穷大时,压缩应变趋于极限压缩应变。垃圾的24h压缩应变与极限压缩应变相差不大,可以近似用24h压缩应变代替极限压缩应变。当压力超过50kPa时,垃圾的极限压缩应变与压力的对数具有直线关系。根据垃圾的压缩试验结果,进一步解释了垃圾的力学压缩机理,制定了垃圾压缩试验的24h稳定标准,建议了垃圾室内压缩试验的方法。
