土木在线论坛 \ 建筑设计 \ 建筑资料库 \ 双圆柱表面压力分布的同步测量
双圆柱表面压力分布的同步测量
发布于:2011-03-08 12:23:08 来自:建筑设计/建筑资料库 [复制转发]
圆柱以及圆柱群一直是钝体绕流研究中最为典型的课题,本文在文献中已有研究成果的基础上,采用对双圆柱同时进行同步测压的方法,在串列、并列和斜置三种典型排列方式以及不同间距下,对双圆柱绕流问题——特别是脉动气动力的特性——进行了实验研究。 为了完成本实验,首先开发了一套32通道同步压力测量系统,标定了各个通道的频响特性,编制了对传压管道造成的信号畸变进行反演修正的程序。通过对单圆柱绕流进行同步测压,并和文献中的结果进行对比,验证了本套同步测压系统的可靠性。 在同步测压的基础上,本文主要研究了双圆柱绕流以下几个方面的问题: 1.表面压力分布的时均和脉动特性; 2.气动力的时均和脉动特性; 3.利用功率谱分析气动力脉动频率和旋涡脱落之间的关系; 4.两个圆柱之间脉动升力的相关分析和相位关系; 5.两个圆柱之间分离点压力的相关分析和相位关系; 6.分离点脉动压力和圆柱周向压力分布的相关情况,以及脉动气动力和周向压力分布的相关情况; 7.瞬时压力分布; 8.利用概率密度分布函数分析脉动气动力的统计特征。 本文的实验结果再次证实了双圆柱绕流的流态会在某些间距上出现突变,而在这些临界间距之间,流态则保持相对的稳定。在串列、并列、斜置三种排列方式下,气动力的最强脉动都出现在两圆柱的间距稍大于各自临界间距的位置。通过对脉动气动力和脉动压力之间的相关分析发现,可以采用某些特殊位置测点的脉动压力来表征脉动气动力。
电加热器
Flow around single circular cylinder and grouped circular cylinders is the most typical problem which is paid much attention in the research of blunt body flow. In this paper, based on the existing research in the literatures, flow interference between two circular cylinders in three representative arrangements(in tandem, side-by-side and staggered)—especially the characteristics of fluctuating aerodynamic forces—was investigated experimentally by simultaneous multi-pressure measurement.In present experiment, a 32-channel simultaneous multi-pressure measurement system was developed and the dynamic characteristics of each channel which were used in the program of the correction for distorted pressure signals through the pressure transfer pipe were calibrated. The reliability of the system was verified by measuring the fluctuating pressure distribution of single circular cylinder and comparing the results with those in the literatures.Based on the results of the measurements of fluctuating pressure distribution, the following aspects of flow around two circular cylinders were carefully studied:1. The characteristics of mean and fluctuating surface pressure distribution;2. The characteristics of mean and fluctuating aerodynamic forces;3. The relationship between the frequencies of fluctuating aerodynamic forces and vortex shedding by the power spectrum analysis;4. The correlation between the fluctuating aerodynamic forces of two circular cylinders;5. The correlation between the fluctuating pressure at separation point of two circular cylinders;6. The correlation between fluctuating pressure at separation point and those around the whole circumference, and the correlation between fluctuating aerodynamic forces and fluctuating pressure around the whole circumference;7. The instantaneous pressure distribution;8. The statistical characteristics of the fluctuating aerodynamic forces analysed by PDF(probability distribution function).The jump between different flow patterns at certain critical position was discovered again in present experiment, and the flow patterns were relatively steady between the critical positions. In the three arrangements, the maximum of the fluctuating aerodynamic forces all appeared at the position when the distance between the two circular cylinders was appreciably longer than critical value. The correlation analysis of the fluctuating aerodynamic forces and the fluctuating pressure distribution showed that the fluctuating aerodynamic forces can be expressed by the fluctuating pressure at special positions.
建筑资料库
13.61 万条内容 · 216 人订阅
渠道自动运行鲁棒控制
渠道运行控制系统是根据渠道系统的信息来控制渠道水位、流量的基本系统。目的在于提高渠系的全面调度运行水平,改善输水效率,实现适时适量地供水,避免供水的不足与浪费,降低调度运行费用,从而达到提高水资源利用率的目的,并为用水单位提供较好的服务。 渠道闸门关启时,带来很大的回波和扰动,传感器测量误差,自然界突发事件、渠道控制模型参数变量等都会带来系统的不确定性。作者首次将鲁棒控制应用在渠道运行控制当中,旨在系统性能最大满足和不确定性的抑制之间寻求调节及优化方案。 本论文根据渠道运行系统多输入多输出、运行状况多变、特点,推导了渠道运行控制系统的数学模型。描述渠道系统的控制过程采用的是圣·维南方程,为了便于用鲁棒控制理论解决渠道运行控制问题,对圣·维南方程作了离散化和线性化的处理。离散化的方法是明渠非恒定流数值解中的插值方法,线性化方法采用的是控制论中常用的台劳级数展开方法。为了实现渠道鲁棒控制,将水流的过渡过程用状态空间方法进行描述,由于多个渠池耦合时,系统状态矩阵过大,为后面鲁棒控制的优化与计算造成困难,本文采用了基于截断的均衡模型降阶方法,从而为后面渠道鲁棒控制铺路,为了对控制过程有更清楚的了解,并用状态空间进行了仿真。 然后,本论文介绍了H∞控制思想:这种摄动系统可以理解成取自某一个集合,那么实际被控对象可以描述为一个系统集(Σ0,△Σ)。其中,Σ0是模型的理想部分成为标称系统;△Σ表示不确定性因素所构成的某个可描述集。这样,实际系统Σ可以看成是标称系统Σ0与不确定因素△Σ的集合。本论文讨论了渠系闸门驱动环节的参数摄动,着重研究了水流流量与节制闸闸孔流量系数、闸孔开度Um、上下游水位差△h之间的摄动关系,看出由于闸孔开度Um,上下游水位差的扰动而导致水流流量△h的不确定性,从而可将不确定因素分离,实施抑制手段,使流量的不确定性限制在一定的范围之内;同时本文也讨论了非参数摄动界函数的确定,各种处理系统摄动机
