土木在线论坛 \ 建筑设计 \ 建筑资料库 \ 土木工程专业英语论文
土木工程专业英语论文
发布于:2011-03-07 14:50:07 来自:建筑设计/建筑资料库 [复制转发]
Explain the nature and utilization of the main types of derivative contracts. By reference to past cases explain the main litigation risks that firms engaging in derivative contracts face
Executive summary:
Along with international financial markets in recent years increasingly prosperous, more and more enterprises use financial derivatives very actively, take risk control strategy into capital operation to low cost of additional financing and avoid risk of exchange rate, interest rate. Since 1990s, the risk of financial derivatives markets in the incident has appealed great public concerning. Financial derivatives as the most prominent representative of virtual financial both have positive features, but also negative features, which one to play the function mostly depends on the financial ecological environment it exists in. In the macro-financial, financial derivatives, when upgrading of the economic capacity of the distribution and efficiency of resources, but also improve the financial system and cumulative systemic risks. The risk of financial derivatives in micro-finance is not the unique, through a number of channels can be dispersed or transferred. For the financial derivatives market characteristics and trends of the development, take full advantage of the function of the market due to financial derivative products, while also effectively prevent related risks which is a major issue for the development of the financial markets. The paper firstly analyze the formation and functions of derivative financial instruments and its law nature, then take the analysis of the causes of the risk, at last illustrate enterprises on how to use the derivative tools and the issues should pay attention to, as well as how the state manage risk.
1. Introduction
1.1 brief descriptions of main types of derivative contracts
1.2 The nature of derivative contracts
5. Conclusion
As the globalization of world economy and international financial markets, the international economic environment is complex and changing with financial instruments innovation timely, enterprises should not shy away from the existence of derivative financial instruments, but should pay full attention to its financial management functions, avoid excessive speculation, and correctly use derivatives for corporate financial services.
Reference:
Huang Meifen, Market modernization, Implication and research on derivatives in the financial management of enterprises, May 2007
Ma Mingchen&Li Hongyou, Accounting and Finance, Analysis on the development of financial derivatives markets and risk management, June 2006.
Wang Qianfeng&Zhang Weixin, Political and judicial, 1, the legal nature of financial derivatives trading, No.6 Dec.10, 2006
Wang Xiaoxin&Chang Zhonghai, Productivity study-financial and monetary, further understanding of financial derivatives function and the risk, No.4.2007
  • daniel2037
    daniel2037 沙发
    没中文~
    2011-05-12 09:03:12
  • ixyy
    ixyy 板凳
    没有中文的啊
    2011-03-15 17:18:15
建筑资料库
13.61 万条内容 · 216 人订阅
吊重防摇控制的起重机快速对位关键技术研究
起重机的小车和吊重之间一般采用柔性钢绳联结,由于大、小车和吊重存在惯性,小车或大车的运行使吊重产生摇摆,不利于起重机快速对位。一般吊重防摇的被动控制较主动控制容易实现。吊重防摇、减摇的型式一般有机械式、液压油缸式、钢丝绳索式、机械电子式和智能电子式,文中的研究重点在液压油缸式和智能电子式减摇系统。对起重机吊重系统的动力学分析是解决起重机快速对位问题的基础。文中由桥式起重机建立了起重机吊重系统动力学方程,并在线性简化的基础上得出吊重二自由度摆角模型。仿真结果表明:吊重的起升绳长和大、小车运行的加(减)速度是影响吊重摆角的主要因素,其中大、小车运行加(减)速度对摆角的影响较绳长对摆角的影响显著:起重机的大车和小车运行对吊重摇摆的影响效果是相同的。液压油缸式减摇系统在集装箱起重机中应用较多,为了能更好地为液压减摇系统的工程设计提供理论依据和指导,文中根据液压减摇系统的结构特点和小车吊重系统的运动特点对液压油缸式减摇系统在工程适用范围内建立了动力学方程,对减摇系统进行了动力学分析,模拟实际工况进行了动态仿真,结果表明:吊重摆角按指数形式衰减,影响减摇系统减摇效果的因素有减摇系统的结构参数、起升质量、起升绳长和起升速度。对于具体的液压减摇系统,在最佳结构参数载荷比范围或匹配起升质量时,可以得到良好的减摇效果。一般通过相应的传感器实时采集小车位置和速度、吊重摆角和摆角角速度以及小车驱动力等状态变量信息,并提供给防摇控制系统。考虑到吊重摆角等变量现场测量的难度和成本,文中针对电压控制小车驱动电机的小车吊重动力学系统,通过设置全状态观测器或降维观测器对相关变量进行现场观测,即重构状态变量空间,从而将相关变量的估计信息提供给防摇控制系统。通过采集小车位置信息可以设置全状态观测器对包括小车位置在内的所有状态变量进行观测:通过采集小车位置和速度信息可以设置降维观测器对吊重摆角、摆角角速度和驱动力进行观测。观测器的相应状态变量的观测时间与小车吊重系统动力学参数、观测器的极点和相应状态变量的初始值有关。在给定系统动力学参数和相应状态变量的初始条件下可以绘制观测器极点与对应状态变量的观测时间关系曲线,为了使观测器精确重构状态变量空间并具有良好的动态特性,可以将观测器的极点配置在复平面负实轴上和该曲线的平缓变化区域。由小车吊重开环系统动力学特性和开环系统的极点在复平面的分布形态,开环系统本身是不稳定的。通过引入状态反馈增益调节器构成闭环控制系统,其中状态变量信息由传感器现场采集或观测器观测所得。采用极点配置法(极点位移法),通过考虑控制系统复平面上一对闭环主导极点,控制系统的其余极点可以配置在离这对主导极点左侧较远处,用类似二阶系统性能分析方法获得反馈控制器的增益调节参数,通过调节参数配置反馈控制系统的极点为期望极点,从而使吊重的摆动能在小车的目标位置和期望时间衰减为零。当反馈控制系统引入状态观测器时,要求观测器对状态变量的观测速度比反馈控制器对状态变量的调节速度快。文中进行了观测器和反馈控制器的设计,仿真结果表明在小车目标位置、指定调节误差范围内吊重摆角能在期望的时间衰减为零,各状态变量均有良好的动态响应特性,说明了观测器和控制器设计的合理性和有效性。起重机现代智能电子吊重防摇控制系统的物理实现须建立在现代电子电路设计基础上。文中对起重机快速对位的实现提出基于控制器局域网(CAN)总线形式的数字信号处理(DSP)控制系统,合理设计了CAN总线控制系统的智能节点电路,对吊重摆角的三角形测量方法给出了具体实施方案。这些关键技术的解决是吊重防摇控制理论和方法进一步物理实现的前期工作。
