土木在线论坛 \ 建筑结构 \ 结构资料库 \ 纵筋及箍筋对构件受剪承载力
纵筋及箍筋对构件受剪承载力
发布于:2011-02-15 11:00:15 来自:建筑结构/结构资料库 [复制转发]
论文简介:
钢筋棍凝土受弯构件中纵筋用量以及箍筋强度等级是影响斜截面受剪承载力的
重要因素& 现行规范的受弯构件斜截面受剪承载力计算公式!∋ () ∗于+ 􀀁% 没有计人纵筋用最
的影响, 且箍筋限于∗ 、
, 级钢筋& 本文研究了纵筋用量对斜截面受剪承载力的影响, 分析
和探讨了箍筋使用, 级钢筋时正常使用阶段的斜裂缝宽度控制等问题
附件名:20112151297738803284.zip
文件大小:240K
(升级VIP 如何赚取土木币)
  • 李志凯
    李志凯 沙发
    掏钱在网上买的呀,支持一下
    2011-02-15 17:36:15
结构资料库
41.29 万条内容 · 428 人订阅
土木工程毕业设计英文翻译论文
论文简介: Structural Forms Structural forms, such as the beam or the arch ,have developed through the ages in relation to the availability of materials and the technology of the time. The arch, for instance, undoubtedly developed as a result of the availability of brick. In the technology of buildings .every structure must work against gravity ,which tends to pull everything down to the ground .A balance must therefore be attained between the force of gravity ,the shape of the structure ,and the strength of the material used. To provide a cover over a sheltered space and permit openings in the walls that surround it ,builders have developed four techniques are post and lintel, arch and vault, truss, and cantilever construction.
