土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ CAD命令简码
CAD命令简码
发布于:2006-03-17 16:37:17 来自:建筑设计/CAD下载及教程 [复制转发]
运行 appload 在弹出窗口的启动组中附上自己的命令简码.就可以大大提高自己的工作效率了
修改命令简码:用记事本打开命令简码.lsp,就可以随心所欲的调整绘图快捷键了
(defun c:x ()(command "xplode"))
(defun c:a ()(command "arc"))
(defun c:b ()(command "block"))
(defun c:c ()(command "circle"))
(defun c:d ()(command "erase"))
(defun c:dg ()(command "dimlinear"))
(defun c:dag ()(command "dimaligned"))
(defun c:dr ()(command "dimradius"))
(defun c:dd ()(command "dimdiameter"))
(defun c:da ()(command "dimangular"))
(defun c:dc ()(command "dimcontinue"))
(defun c:ds ()(command "dimstyle"))
(defun c:e ()(command "extend"))
(defun c:f ()(command "fillet"))
(defun c:fd ()(command "dimedit"))
(defun c:ggg ()(command "group"))
(defun c:h ()(command "bhatch"))
(defun c:i ()(command "insert"))
(defun c:j ()(command ""))
(defun c:k ()(command ""))
(defun c:l ()(command "line"))
(defun c:m ()(command "move"))
(defun c:n ()(command ""))
(defun c:o ()(command "offset"))
(defun c:p ()(command "pan"))
(defun c:q ()(command ""))
(defun c:rrr ()(command "redraw"))
(defun c:s ()(command "stretch"))
(defun c:t ()(command "mtext"))
(defun c:u ()(command "undo"))
(defun c:v ()(command "move"))
(defun c:w ()(command "wblock"))
(defun c:y ()(command ""))
(defun c:z ()(command "zoom"))
(defun c:g ()(command "line"))
(defun c:cc ()(command "_copy"))
(defun c:vv ()(command "view"))
(defun c:tf ()(command "justifytext" (ssget) "" "f"))
(defun c:ff ()(command "offset"))
(defun c:gg ()(command "pline"))
(defun c:r ()(command "rotate"))
(defun c:el ()(command "ellipse"))
(defun c:ss ()(command "solid"))
(defun c:rr ()(command "mirror"))
(defun c:ar ()(command "array"))
(defun c:sc ()(command "scale"))
(defun c:tr ()(command "trim"))
(defun c:ex ()(command "extend"))
(defun c:br ()(command "break"))
(defun c:ge ()(command "pedit"))
(defun c:q ()(command "properties"))
(defun c:qq ()(command "matchprop"))
(defun c:se ()(command "dsettings"))
(defun c:st ()(command "style"))
(defun c:dt ()(command "dtext"))
(defun c:ed ()(command "ddedit"))
(defun c:bb ()(command "insert"))
(defun c:ga ()(command "layer"))
(defun c:ccc ()(command "color"))
(defun c:gt ()(command "linetype"))
(defun c:gs ()(command "ltscale"))
(defun c:adc ()(command "adcenter"))
(defun c:xg ()(command "xline"))
(defun c:mg ()(command "mline"))
(defun c:rec ()(command "rectang"))
(defun c:sg ()(command "spline"))
(defun c:zz ()(command "zoom" "p"))
(defun c:za ()(command "zoom" "a"))
(defun c:ze ()(command "zoom" "e"))
全部回复(10 )
  • fancy0020
    fancy0020 沙发
    支持该种说法。
    2006-04-13 20:33:13
  • jsj0425
    jsj0425 板凳
    要在别人机子上使用CAD方便的话
    自己最好一直使用CAD默认命令和快捷键,不要使用自定义的
    那样到别人机子上也照样顺手啦~!~
    2006-03-25 16:09:25
CAD下载及教程
52.09 万条内容 · 690 人订阅
请教高手,文件名称与图内标题栏名称从属关系
见过一张机械图,图内标题栏的图名是随该图的文件名的改动而改变的,请教哪位高手指教以下!
