土木在线论坛 \ 建筑结构 \ ETABS \ ETABS算得x向基底剪力异常小(附 EDB文件)
发布于:2006-03-15 21:49:15 来自:建筑结构/ETABS [复制转发]
12层框剪结构,带一层地下室,用pkpm算得x向基底剪力为3020kN,而用ETABS算得x向基底剪力异常小,仅为771kN。
将EDB文件上传,请大家帮忙看哪出了问题。
全部回复(3 )
  • gxinhua1984
    gxinhua1984 沙发
    本想帮你看看模型,可是你用的是8.5.6版的,而我是8.4.8,所以不能找开.况且你又没有将PKPM模型传上来,没法比较.
    估计你的模型总质量不对或结构有许多点没有约束,请检查!
    2008-11-09 13:59:09
  • patamd
    patamd 板凳
    Check the mass source.
    Base shear = seismic factor X lumped weight.
    If you want to use dead load as one of the source of the weight to evaluate the base shear. Check the box to right of "From Self and Specified Mass and Loads", and add DEAD load with multiplier of 1.
    Define --->mass source
    If you do not chose dead load to be the source of the weight. The base shear might be calculated using the self-weight of the structure only and you might get a small value of base shear.
    2008-04-01 00:37:01
ETABS
1.67 万条内容 · 53 人订阅
Etabs如何由英文版转为中文版
问一下,安装etabs后菜单都是英文,怎么由英文版转为中文版啊?据说在help菜单下有这个功能,我咋没找到?!
