土木在线论坛 \ 施工技术 \ 建筑施工 \ Plaxis Professional 8.2
发布于:2006-03-10 00:05:10 来自:施工技术/建筑施工 [复制转发]
Plaxis大型岩土工程有限元设计计算软件(包括Plaxis动力模块,PlaxFlow地下水渗流模块,Plaxis三维隧道软件 V2,Plaxis三维基础软件(可以计算现行的所有大型桩筏基础) 。Plaxis可分析岩土工程学中2D 和 3D 的变形,稳定性,以及地下水渗流等。岩土工程应用需要十分先进的构造模型来模拟土壤的非线性和时间依赖行为。 另因为土壤是多状态物质,需要专门的程序来处理土壤中流体静力学和非流体静力学气孔压力。这些问题现在都可以用Plaxis来分析和处理了。
与当前的FLAC,ansys,abcus相比,Plaxis具有本构模型丰富,而且可以用户根据需要自定义本构模,操作界面简单,易学!
Plaxis is a range of finite element packages intended for 2D and 3D analysis of deformation, stability and groundwater flow in geotechnical engineering.
Geotechnical applications require advanced constitutive models for the simulation of the non-linear and time-dependent behaviour of soils. In addition, since soil is a multi-phase material, special procedures are required to deal with hydrostatic and non-hydrostatic pore pressures in the soil. Although the modelling of the soil itself is an important issue, many geotechnical engineering projects involve the modelling of structures and the interaction between the structures and the soil. Plaxis is equipped with special features to deal with the numerous aspects of complex geotechnical structures.
http://www.9iv.com/down/soft/2460.htm?id=236880
有需要的我就下载下来
全部回复(29 )
  • fairfanfan
    fairfanfan 沙发
    下载下来吧,太需要了!!!!!
    2009-10-23 14:27:23
  • oking
    oking 板凳
    很需要啊。楼主上传啊
    2008-10-11 09:48:11
建筑施工
66.04 万条内容 · 1649 人订阅
市政基础设施工程施工技术文件管理规定(转载)
市政基础设施工程施工技术文件管理规定,建设部文件[2002](221号),内附详细的文件及规定,有许多市政施工技术常用表格(附:市政基础设施工程施工技术文件主要项目统一规定表格、表式),可以供广大网友参考,从建工之家处转载。如论坛已有朋友上传,请告诉一声后删除。
