土木在线论坛 \ 站务休闲 \ 站长办公室 \ 2006-3-8热泪庆祝
2006-3-8热泪庆祝
发布于:2006-03-08 14:48:08 来自:站务休闲/站长办公室 [复制转发]
本电气站点于今天凌晨0:00,注册人数200523,突破20万大关,每一个脚印都是大家团结的成功。
全部回复(25 )
  • wyxsacf
    wyxsacf 沙发
    热烈祝贺
    2006-03-16 12:25:16
  • ttt001
    ttt001 板凳
    论坛在线统计: 目前论坛总共有 359 人在线。 其中注册用户 189 人, 游客 170 人。 管理员 版主 自己
    0601_kaiselin 13304421090z ahd-lxj@co163 ajgd0 alen_du alisakura alxcalxc angelo_yu
    ashlli auto_16848 badm010 bengmenwen bqg calmsea caolihe18 cgh5123
    chaizhixia198173 checzxr@co163 chenhhxx chenying1227 chenzhen11 chinaying99 cht3068 cnwhyy
    coff cr129 cuicui007 dao569 ddcola123 ddxxhh-911 dgrpower dlgc_hl
    dlsfltb dyg_001 easunlee evangenlin312 fayu fljrose.1981 forefly fsm0412
    fytgf fzisme g12345678 ganggang4699 gdjywxp gg63 hain hanghost
    herolis he_kangaaa hfdss hhj3738 hhlingling hi@dq hldlqw hnlidexiang
    huangyu9966 huitianye hy.6416 icebird ihf jbtp06 jd633 jetzw
    jiafei5566 jianghua139129 jiechuang_w jinchen9408 jllwils2005 join_in jossh@co163 jps8chr
    jyqiang8 kanbudong kerry2005 king lcr760717 lg16666 lhc199725 lhdlgmz
    lhslhz lifumin liminghuimr linjj-jy liu80906 liuhua1990 liujiefeng liutiehua
    liyigs lj198832 lj666 lk8609654 long_hao lovecntong ltabc123 lwxlyc
    lybdhz lyking007 mab3630 miaomiao1222 mopper-lee netling ngy7023 nth2005
    nweiyi pandog pangenuine parapary polophoto pwb-1959 pzhrsz qianhj
    qianjinxianfeng qibo638 qiuhf qq131121 qrg442 qsba rainy917@co163 renshenghebi
    renshuangli8888 ronaldinho roseme2004 sadeli saimanwang1999 schawa senica shdq2777
    smooth800715 ssppitx success2006 sunhan327 tideyuan ttt001 viny w.shuo
    wallams55 wang9117 wangjin2005 wangwenfeng987 wd08160816 whatforme wj98329 wlyzhchf
    wutongyuych wuwei13619142279 wyxsacf wzh4830 xijia12 xmznt xudi1234 xueyang713
    xxggff xyhwww yang.xiaoyang yang1455 yangjunjie1983 YDQ365 yifan166 yingzi123999
    ysl0038 yuqing__55 yusonghan yx1113 yxldcm zaidengjitian zdbdzq zergboy
    zgd301 zhang197408 zhangshukuan zhangzhanbiao88 zhenxin zhh_1977 zhourong336 zhulj@co163
    zhu_qingzheng zhxy4206 zjs591 zjyxinyuan zqxlj7082 zwm.1982 大胡子 盗亦有道
    后发制人 开关 石大头 小电容美眉 张元方
    2006-03-15 16:44:15
站长办公室
61.75 万条内容 · 51 人订阅
网页页面应做一些修改
如果回了贴子就再回不到到“回贴前的位置”,如你在普钢版块第36页"关于抗剪键的设置”这一主题下回复一贴子,你就再回不到第36页,你只有再点“ 普通钢结构”进入第一页,因此不知到底看过了哪些主题。因此建议可以连续回退,即便回了帖。每一个贴子应固定在一个位置,不要随回贴窜来窜去,对某一主题有兴趣,下次可能就再也找不到它了。这样可以尽可能减小诸如:支持,我顶,顶一下等空洞回复,减小阅读量,有时一主题被顶了20几下,才有一有实质性的回复,没有奈心,早就不看了。进入这种论坛的人应是为了交流,不是过家家。回复、提出主题是提高自己,也是尽社会责任。
