土木在线论坛 \ 给排水工程 \ 给排水资料库 \ 各位看看这英文标题是什么意思啊,标题我都不懂
发布于:2006-02-24 15:10:24 来自:给排水工程/给排水资料库 [复制转发]
Treatment of Wastewater from a Whey Processing Plant
Using Activated Sludge and Anaerobic Processes
全部回复(4 )
  • jiangshi1997
    jiangshi1997 沙发
    应该是乳化废水的处理
    2006-03-07 19:59:07
  • jnbbnnh
    jnbbnnh 板凳
    这是文章,既然是高Wastewater from a whey processing
    plant was treated in two on-site pilot
    plants, a three-stage activated sludge
    plant and an anaerobic reactor, each of
    which had the capacity of treathg 230 W
    h of wastewater. The activated sludge
    treatment was very effective. It reduced
    99% of 5d biochemical oxygen demand
    of the plant wastewater (from an average
    of 1062 to 9 mg/L) and 91% of total
    Kjeldahl nitrogen (from 109 to 10 m&)
    after a total retention time of 19.8 h. The
    intermediate 5d biochemical oxygen de-
    mand reductions were 86% after 3.8 h in
    the first stage and 97% after another 8 h
    in the second stage. The completely
    mixed
    anaerobic reactor reduced only
    87% of 5d
    after 2 d of retention. However, with an
    additional 8 h of activated sludge treat-
    ment the total 5d biochemical oxygen
    demand was reduced by 99%. Both pilot
    plants were operated smoothly in spite of
    the considerable fluctuations in pollutant
    levels of the plant wastewater.
    (Key words: activated sludge, anaerobic
    treatment, whey wastewater)
    Abbreviation key: BOD5 = 5-d biochemical
    oxygen demand, COD = chemical oxygen de-
    mand, HRT = hydraulic retention time,
    MLVSS = mixed liquor volatile suspended
    solids, TOC = total organic carbon, TSS =
    total suspended solids, VSS = volatile sus-
    pended solids.
    INTRODUCTION
    Whey is the liquid waste generated from the
    process of cheese making. It constitutes 80 to
    Received April 9, 1990.
    Accepted December 26, 1990. 手就发挥一下吧
    2006-02-24 15:26:24
给排水资料库
22.46 万条内容 · 568 人订阅
有关PVC-U塑料管的国标问题
请问,有那位知道PVC有分排水管,雨水管的国标做法吗?就是其相应的管壁厚,长度是怎么样?是否排水的比雨水的厚?还有排污管呢?谢谢。。
