土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 结构专业专业词汇汇总
结构专业专业词汇汇总
发布于:2006-02-22 09:40:22 来自:建筑结构/钢结构工程 [复制转发]
建筑专业及钢结构专业词汇
acceptable quality 合格质量
acceptance lot 验收批量
aciera 钢材
admixture 外加剂
against slip coefficient between friction surface of high-strength
bolted connection 高强度螺栓摩擦面抗滑移系数
aggregate 骨料
air content 含气量
air-dried timber 气干材
allowable ratio of height to sectional thickness of masonry wall or
column 砌体墙、柱容许高厚比
allowable slenderness ratio of steel member 钢构件容许长细比
allowable slenderness ratio of timber compression member 受压木构件容许长细比
allowable stress range of fatigue 疲劳容许应力幅
allowable ultimate tensile strain of reinforcement 钢筋拉应变限值
allowable value of crack width 裂缝宽度容许值
allowable value of deflection of structural member 构件挠度容许值
allowable value of deflection of timber bending member 受弯木构件挠度容许值
allowable value of deformation of steel member 钢构件变形容许值
allowable value of deformation of structural member 构件变形容许值
allowable value of drift angle of earthquake resistant structure
抗震结构层间位移角限值
amplified coefficient of eccentricity 偏心距增大系数
anchorage 锚具
anchorage length of steel bar 钢筋锚固长度
approval analysis during construction stage 施工阶段验算
arch 拱
arch with tie rod 拉捍拱
arch—shaped roof truss 拱形屋架
area of shear plane 剪面面积
area of transformed section 换算截面面积
aseismic design 建筑抗震设计
assembled monolithic concrete structure 装配整体式混凝土结构
automatic welding 自动焊接
auxiliary steel bar 架立钢筋
全部回复(36 )
  • yhw2001
    yhw2001 沙发
    真的是个好东西
    谢谢:)
    2007-02-08 10:54:08
  • cly8721
    cly8721 板凳
    辛苦\辛苦!收下啦,谢谢!
    2006-03-20 12:05:20
钢结构工程
46.53 万条内容 · 1223 人订阅
3d3s帮助文件电子版说明(分门别类-好用)
这个是比较好用,分门别类的。一看就明白。觉得好了要顶哦。
