土木在线论坛 \ 人才招聘 \ 学生专栏 \ 哪位大哥帮忙翻译一下 谢谢了(门式钢架)
发布于:2006-02-21 21:41:21 来自:人才招聘/学生专栏 [复制转发]
The input window consists of Configuration panel, Flange &
Web panel, Stiffeners panel, and Welds Panel. The user can enter the
corresponding input for the design of plate girders in those panels.
Span length, lateral supports (similar to applet for design of
beams described in Sec. 5.11), and distributed and concentrated loads are
set in the configuration panel (Fig. 9.29). The loading on the girder may
consist of a uniformly distributed load plus a specified number of
concentrated loads. The concentrated loads are named alphabetically
from left. Alphabets “A” and “B” are reserved for the left and right
supports, respectively. The girder may have either full lateral support or
intermediate lateral supports.
Width, thickness, and steel type of flange plates and thickness
and steel type of the web plate are set in the flange & web panel (9.30a).
To begin the design of a plate girder the user needs to specify the steel
types of flange and web plates only. The applet displays the first design
results as shown in Fig. 9.30b. Like other applets presented in the
previous chapters, this applet requires minimum amount of design entry
to perform a design. However, the user can perform redesigns repeatedly
simply by changing only one or several of the input values.
To design a hybrid girder, the user needs to select the steel types
of flange plates and web plate properly. For impractical values, for
example, if the user selects a steel type for flange plates with lower
strength than that of the web, the applet warns the user with a pop-up
message 帮忙~谢谢
全部回复(4 )
  • zm6487
    zm6487 沙发
    The input window consists of Configuration panel, Flange & Web panel,
    输入窗口包括了构造菜单,翼缘腹板菜单,
    Stiffeners panel, and Welds Panel. The user can enter the corresponding
    加劲板菜单及引弧板菜单。用户在设计梁时在相应的菜单输入信息.
    input for the design of plate girders in those panels. Span length, lateral
                                跨度,侧向支撑
    supports (similar to applet for design of beams described in Sec. 5.11),
    (参见5.11中梁的设计方法),
    and distributed and concentrated loads are set in the configuration panel
    及分布和集中荷载在构造菜单中输入.(图9.29)
    (Fig. 9.29). The loading on the girder may consist of a uniformly
    主梁的荷载通常由
    distributed load plus a specified number of concentrated loads. The
    不均匀分布荷载与几个集中荷载组合而成。
    concentrated loads are named alphabetically from left. Alphabets “A”
    集中荷载从左到右依次按照字母表顺序命名。但字母“A”和“B”
    and “B” are reserved for the left and right supports, respectively. The
    仅分别限左端及右端支坐。
    主梁要么侧向完全支固要么
    intermediate lateral supports. Width, thickness, and steel type of flange
    侧向间断支固. 腹板和翼缘板的板材厚度及种类
    plates and thickness and steel type of the web plate are set in the flange
    要填入腹板及翼缘板窗口。(9.30a)
    & web panel (9.30a). To begin the design of a plate girder the user needs
    开始设计主梁用板之前,用户仅需对腹板及翼缘用板进行具体说明。
    to specify the steel types of flange and web plates only. The applet
    displays the first design results as shown in Fig. 9.30b. Like other applets
    本应用程序的第一部分计算结果如图9.30 b所示。
    presented in the previous chapters, this applet requires minimum amount
    如别的程序一样,本程序也只有设计参数输入达到最小值要求时才能运行。
    of design entry
    尽管如此,用户仅通过改变一个或几个输入值就可以多次重复使用程序设计。
    simply by changing only one or several of the input values. To design a
    hybrid girder, the user needs to select the steel types of flange plates and
    设计组合梁时,用户需谨慎选择腹板及翼缘的钢材。
    web plate properly. For impractical values, for example, if the user selects
    对于一些不合实际的参数,例如:用户选的腹板的强度低于翼缘的强度,软件会以突然冒出的消息对用户发出警告.(结束).
    见笑了.欢迎各位批评、指正、讨论。谢谢
    2006-04-29 12:42:29
  • andyhewitt
    andyhewitt 板凳
    帮你提顶了。
    2006-04-27 17:59:27
学生专栏
23.9 万条内容 · 138 人订阅
谁能帮我搞立体设计
我好困难啊!老师让用粉笔搞个点的立体构造 我都感觉自己想的太素。谁有好点子帮帮忙了!感谢!
