土木在线论坛 \ 站务休闲 \ 闲聊茶吧 \ 测试测试,做做看,很好玩的哦~~
测试测试,做做看,很好玩的哦~~
发布于:2006-02-21 14:18:21 来自:站务休闲/闲聊茶吧 [复制转发]
Hey it is quite accurate!!! Try and see!
嗨,这个测试很准的哦,来试试看。
Take a piece of paper and write down the answers.. The analysis is in the end....
请拿出一张纸一支笔把你的答案写下来,结论就在后面。
Situation: 场景:
You are in a deep deep forest... as you walk on you saw an old hut standing there
你在森林的深处,你向前走,看见前面有一座很旧的小屋。
(1) What is the status of the door? (Opened/closed)
这个小屋的门现在是什么状态?(开着/关着)
(2) You enter the hut and see a table... What is the shape of the table?
(Round/Oval/Square/Rectangle/Triangle)
你走进屋子里看见一张桌子
这个桌子是什么形状的?(圆形/椭圆形/正方形/长方形/三角形)
(3) On top of the table there is a vase... in the vase there is water. How much water is it filled up with?
(Full/Half/Empty)
在桌子上有个花瓶,瓶子里有水,有多少水在花瓶里?(满的/一半/空的)
(4) And what is the vase made of?
[(Glass/porcelain/clay)(metal/plastic/wood)]
这个瓶子是由什么材料制造的? (玻璃/陶瓷/泥土)(金属/塑料/木头)
(5) You walk out of the hut... as you carry on your walk in the forest... you see a waterfall from far...
there is water running down...What is the speed of the water?
(Choose a number ranging from 0 to 10)
你走出屋子,继续向森林深处前进,你看见远处有瀑布飞流直下,请问水流的速度是多少?
(你可以从0—10任意选一个)
(6) Some time after the waterfall... you step on something hard on the ground... as you look down... you see
glistening gold in colour. You bend down and pick it up... it is a keychain chained with keys...
How many key /keys you see hanging on the keychain? (Choose a number ranging from 1 to 10)
过了一会,你走过瀑布,你站在坚硬的地面上,你看见地上有金光闪烁,你弯腰拾起来,是一个带着钥匙的钥匙链。有多少把钥匙拴在上面,你可以任意选一个数字(从1到10)
(7) You walk on and on... trying to find your way out...suddenly you see a castle.
What is the condition of the castle? (Old/new)
你继续向前走,试着找出一条路来,突然你发现眼前有一座城堡。这个城堡是什么样的?
(旧的/新的)
全部回复(20 )
  • guojuan222
    guojuan222 沙发
    楼主,看了你的答案,不全对但有一部分还是正确的,谢谢啦!
    2006-02-23 17:43:23
  • sunhan327
    sunhan327 板凳
    还差不多,嘿嘿
    2006-02-23 17:39:23
闲聊茶吧
114.52 万条内容 · 201 人订阅
刘仪伟经典语录摘(博您一笑^_^)
半块香皂  有位上海观众来信说他想呼吁相关部门授予某家餐厅卫生先进单位称号,的确,现在能在菜里吃出半块香皂的餐厅真的不多了。   代沟   代沟现象越来越厉害。一位母亲对女儿非常生气:这就是现代的年轻人!16岁就交上了男朋友,却忘记了自己母亲32岁的生日。   生病  现在的孩子懂事都早,吴与同就是,有一天她妈妈病了,浑身没劲儿,躺在床上,说做不了饭了,吴与同一挽袖子,说:妈妈,我扶你去厨房!
