土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 2010年新规范目录大全
2010年新规范目录大全
发布于:2010-11-25 20:50:25 来自:建筑结构/混凝土结构 [复制转发]
〖GB/T50001-2010〗房屋建筑制图统一标准
Unified standard for building drawing
〖GB50010-2010〗混凝土结构设计规范
Code for design of concrete structures
〖GB50011-2010〗建筑抗震设计规范
Code for seismic design of buildings
〖GB50039-2010〗农村防火规范
〖GB50061-2010〗66kV及以下架空电力线路设计规范
Code for design of 66kV or under overhead electrical power transmission line
〖GB50072-2010〗冷库设计规范
Code for design of cold store
〖GB50094-2010〗球形储罐施工规范
〖GB/T50103-2010〗总图制图标准
Standard for general layout drawings
〖GB/T50104-2010〗建筑制图标准
Standard for architectural drawings
〖GB/T50105-2010〗建筑结构制图标准
Standard for structural drawings
〖GB/T50106-2010〗建筑给水排水制图标准
〖GB/T50107-2010〗混凝土强度检验评定标准
Standard for evaluation of concrete compressive strength
〖GB/T50114-2010〗暖通空调制图标准
Standard for heating,ventilation and air conditioning drawings
〖GB50118-2010〗民用建筑隔声设计规范
Code for sound insulation design of civil buildings
〖GB/T50125-2010〗给水排水工程基本术语标准
Standard for basic terms of water and wastewater engineering
〖GB/T50138-2010〗水位观测标准
Standard for stage observation
〖GB50147-2010〗电气装置安装工程 高压电器施工及验收规范
Erection works of electrical installations Code for con-struction and acceptance of high voltage appliance
〖GB50148-2010〗电气装置安装工程 电力变压器、油浸电抗器、互感器施工及验收规范
〖GB50151-2010〗泡沫灭火系统设计规范
〖GB50158-2010〗港口工程结构可靠性设计统一标准
〖GB50185-2010〗工业设备及管道绝热工程施工质量验收规范
Code for acceptance of construction quality of industrial equipment and pipeline insulation engineering
〖GB50193-93(2010年版)〗二氧化碳灭火系统设计规范
Code for design of carbon dioxide fire extinguishing systems
〖GB50209-2010〗建筑地面工程施工质量验收规范
Code for acceptance of construction quality of building ground
〖GB50213-2010〗煤矿井巷工程质量验收规范
Code for acceptance of shaft sinking and drifting of coal mine
〖GB50224-2010〗建筑防腐蚀工程施工质量验收规范
〖GB50235-2010〗工业金属管道工程施工规范
〖GB50252-2010〗工业安装工程施工质量验收统一标准
Unified standard for constructional quality acceptance of industrial installation engineering
〖GB50265-2010〗泵站设计规范
Code for design of pumping stations
〖GB50270-2010〗输送设备安装工程施工及验收规范
Code for construction and acceptance of conveyor equipment installation engineering
〖GB50274-2010〗制冷设备、空气分离设备安装工程施工及验收规范
Code for construction and acceptance of refrigeration and air separating equipment installation engineering
〖JGJ7-2010〗空间网格结构技术规程
〖JGJ19-2010〗冷拔低碳钢丝应用技术规程
Technical specification for application or cold-drawn low-carbon wires
〖JGJ25-2010〗档案馆建筑设计规范
Code for design of archives buildings
〖JGJ26-2010〗严寒和寒冷地区居住建筑节能设计标准
Design standard for energy efficiency of residential buildings in severe cold and cold zones
〖JGJ/T77-2010〗施工企业安全生产评价标准
Standard for the work safety assesment of construction company
〖JGJ85-2010〗预应力筋用锚具、夹具和连接器应用技术规程
Technical specification for application of anchorage,grip and coupler for prestressing tendons
〖JGJ88-2010〗龙门架及井架物料提升机安全技术规范
〖JGJ107-2010〗钢筋机械连接技术规程
Technical specification for mechanical splicing of steel reinforcing bars
〖JGJ128-2010〗建筑施工门式钢管脚手架安全技术规范
Technical code for safety of frame scaffoldings with steel tubules in construction
〖JGJ134-2010〗夏热冬冷地区居住建筑节能设计标准
Design standard for energy efficiency of residential buildings in hot summer and cold winter zone
〖JGJ174-2010〗多联机空调系统工程技术规程
Technical specification for multi-connected split air condition system
〖JGJ190-2010〗建筑工程检测试验技术管理规范
Code for technical management of building engineering inspection and testing
〖JGJ195-2010〗液压爬升模板工程技术规程
Technical specification for the hydraulic climbing formwork engineering
〖JGJ196-2010〗建筑施工塔式起重机安装、使用、拆卸安全技术规程
Technical specification for safety installation operation and dismantlement of tower crane in construction
〖JGJ/T197-2010〗混凝土预制拼装塔机基础技术规程
〖JGJ/T198-2010〗施工企业工程建设技术标准化管理规范
Code for management of technical standardization of project construction of construction enterprises
〖JGJ/T199-2010〗型钢水泥土搅拌墙技术规程
Technical specification for soil mixed wall
〖JGJ/T200-2010〗喷涂聚脲防水工程技术规程
Technical specification for spray polyurea waterproofing
〖JGJ/T201-2010〗石膏砌块砌体技术规程
Technical specification for gypsum bloch masonry
〖JGJ202-2010〗建筑施工工具式脚手架安全技术规范
Technical code for safety of implementation scaffold practice in construction
〖JGJ203-2010〗民用建筑太阳能光伏系统应用技术规范
Technical code for application of solar photovoltaic system of civil buildings
〖JGJ/T204-2010〗建筑施工企业管理基础数据标准
Standard for basic data of construction enterprise management
〖JGJ/T205-2010〗建筑门窗工程检测技术规程
Technical specification for inspection of building doors and windows
〖JGJ206-2010〗海砂混凝土应用技术规范
Technical code for application of sea sand concrete
〖JGJ/T207-2010〗装配箱混凝土空心楼盖结构技术规程
Technical specification for assembly box concrete hollow floor structure
〖JGJ/T208-2010〗后锚固法检测混凝土抗压强度技术规程
Technical specification for inspection of concrete compressive strength by post-installed adhesive anchorage method
〖JGJ209-2010〗轻型钢结构住宅技术规程
Technical specification for lightweight residential buildings of steel structure
〖JGJ/T210-2010〗刚—柔性桩复合地基技术规程
Technical specification for rigid-flexible pile composite foundation
〖JGJ/T211-2010〗建筑工程水泥—水玻璃双液注浆技术规程
Technical specification for cement-silicate grouting in building engineering
〖JGJ/T212-2010〗地下工程渗漏治理技术规程
全部回复(42 )
  • charise
    charise 沙发
    来晚了,有些需要更新
    2012-05-07 19:13:07
  • qianjing99
    qianjing99 板凳
    这么多,谢谢,了解了
    2011-10-18 09:36:18
140.16 万条内容 · 2199 人订阅
有四川审图问题汇总吗???
最近做四川项目,谁有四川审图问题集锦什么的?令外重庆地区桩扩大头 有示意图吗?最好是CAD或PDF版的?:handshake :handshake
