土木在线论坛 \ 建筑结构 \ 混凝土结构 \ Concrete Repair 混凝土修补 (英语原版书)
发布于:2010-11-14 11:07:14 来自:建筑结构/混凝土结构 [复制转发]
The Unified Facilities Criteria (UFC) system is prescribed by MIL-STD 3007 and provides
planning, design, construction, sustainment, restoration, and modernization criteria, and applies
to the Military Departments, the Defense Agencies, and the DoD Field Activities in accordance
with USD(AT&L) Memorandum dated 29 May 2002. UFC will be used for all DoD projects and
work for other customers where appropriate. All construction outside of the United States is
also governed by Status of forces Agreements (SOFA), Host Nation Funded Construction
Agreements (HNFA), and in some instances, Bilateral Infrastructure Agreements (BIA.)
Therefore, the acquisition team must ensure compliance with the more stringent of the UFC, the
SOFA, the HNFA, and the BIA, as applicable.
UFC are living documents and will be periodically reviewed, updated, and made available to
users as part of the Services’ responsibility for providing technical criteria for military
construction. Headquarters, U.S. Army Corps of Engineers (HQUSACE), Naval Facilities
Engineering Command (NAVFAC), and Air Force Civil Engineer Support Agency (AFCESA) are
responsible for administration of the UFC system. Defense agencies should contact the
preparing service for document interpretation and improvements. Technical content of UFC is
the responsibility of the cognizant DoD working group. Recommended changes with supporting
rationale should be sent to the respective service proponent office by the following electronic
form: Criteria Change Request (CCR). The form is also accessible from the Internet sites listed
below
140.17 万条内容 · 2228 人订阅
05G359-3悬挂运输设备轨道图集的问题
05G359-3悬挂运输设备轨道图集在P13页表中选用I50a时,与混凝土梁连接的连接件编号为33或34,翻看P61页连接件33、34感觉根本对不起来嘛,纳闷死了,哪位达人可以点拨下啊,万分感激
