土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 图像批量裁剪.LSP
图像批量裁剪.LSP
发布于:2010-11-12 11:04:12 来自:建筑设计/CAD下载及教程 [复制转发]
图像批量裁剪.LSP;|'((-1 . <图元名: 7e135ea0> ) (0 . "IMAGE") (330 . <图元名: 7e135cf8> ) (5 . "94") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbRasterImage" ) (90 . 0) (10 14.2588 17.2157 0.0) (11 0.0104167 0.0 0.0) (12 6.37816e-019 0.0104167 0.0 ) (13 1024.0 768.0 0.0) (340 . <图元名: 7e135e90> ) (70 . 7) (280 . 0) (281 . 50) (282 . 50) (283 . 0) (360 . <图元名: 7e135e98> ) (71 . 1) (91 . 2) (14 -0.5 -0.5 0.0) (14 1023.5 767.5 0.0) )
'((-1 . <图元名: 7e135ea0> ) (0 . "IMAGE") (330 . <图元名: 7e135cf8> ) (5 . "94") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbRasterImage" ) (90 . 0) (10 14.2588 17.2157 0.0) (11 0.0104167 0.0 0.0) (12 6.37816e-019 0.0104167 0.0 ) (13 1024.0 768.0 0.0) (340 . <图元名: 7e135e90> ) (70 . 7) (280 . 1) (281 . 50) (282 . 50) (283 . 0) (360 . <图元名: 7e135e98> ) (71 . 1) (91 . 2) (14 0.0919184 123.242 0.0) (14 1023.5 749.188 0.0) )
|;(defun c:tt () (setq i 0) (if (setq ss (ssget '((0 . "IMAGE")))) (repeat (sslength ss) (setq en (ssname ss i) ent (entget en) ent (subst '(280 . 1) (assoc 280 ent) ent) ent (subst '(14 0.0919184 123.242 0.0) '(14 -0.5 -0.5 0.0) ent) ent (subst '(14 1023.5 749.188 0.0) '(14 1023.5 767.5 0.0) ent) ) (entmod ent) (setq i (1+ i)) ) ) (princ))
  • longer1000
    longer1000 沙发
    2011-09-29 14:49:29
  • lishaohua616
    lishaohua616 板凳
    一串代码 楼主是程序开发的吗 不懂
    2010-11-13 14:31:13
CAD下载及教程
52.09 万条内容 · 690 人订阅
获取当前图档全部系统变量.lsp
获取当前图档全部系统变量.lsp(setq lst '("ACADLSPASDOC" "ACADPREFIX" "ACADVER" "ACISOUTVER" "AFLAGS" "ANGBASE" "ANGDIR" "APBOX" "APERTURE" "AREA" "ATTDIA" "ATTMODE" "ATTREQ" "AUDITCTL" "AUNITS" "AUPREC" "AUTOSNAP"
