土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 请教同行
请教同行
发布于:2010-11-10 18:37:10 来自:建筑设计/CAD下载及教程 [复制转发]
我的CAD软件突然使用快捷键,移动变成复制了怎么办?
  • huofei-email
    huofei-email 沙发
    3A, *3DARRAY
    3DMIRROR, *MIRROR3D
    3DNavigate,*3DWALK
    3DO, *3DORBIT
    3DW, *3DWALK
    3F, *3DFACE
    3M, *3DMOVE
    3P, *3DPOLY
    3R, *3DROTATE
    A, *ARC
    AC, *BACTION
    ADC, *ADCENTER
    AECTOACAD, *-ExportToAutoCAD
    AA, *AREA
    AL, *ALIGN
    3AL, *3DALIGN
    AP, *APPLOAD
    AR, *ARRAY
    -AR, *-ARRAY
    ATT, *ATTDEF
    -ATT, *-ATTDEF
    ATE, *ATTEDIT
    -ATE, *-ATTEDIT
    ATTE, *-ATTEDIT
    B, *BLOCK
    -B, *-BLOCK
    BC, *BCLOSE
    BE, *BEDIT
    BH, *HATCH
    BO, *BOUNDARY
    -BO, *-BOUNDARY
    BR, *BREAK
    BS, *BSAVE
    BVS, *BVSTATE
    C, *CIRCLE
    CAM, *CAMERA
    CH, *PROPERTIES
    -CH, *CHANGE
    CHA, *CHAMFER
    CHK, *CHECKSTANDARDS
    CLI, *COMMANDLINE
    COL, *COLOR
    COLOUR, *COLOR
    CO, *COPY
    CP, *COPY
    CT, *CTABLESTYLE
    CYL, *CYLINDER
    D, *DIMSTYLE
    DAG, *DIMALIGNED
    DA, *DIMANGULAR
    DAR, *DIMARC
    JOG, *DIMJOGGED
    DBA, *DIMBASELINE
    DBC, *DBCONNECT
    DC, *ADCENTER
    DCE, *DIMCENTER
    DCENTER, *ADCENTER
    DCO, *DIMCONTINUE
    DDA, *DIMDISASSOCIATE
    DDI, *DIMDIAMETER
    DED, *DIMEDIT
    DI, *DIST
    DIV, *DIVIDE
    DJO, *DIMJOGGED
    DLI, *DIMLINEAR
    DO, *DONUT
    DOR, *DIMORDINATE
    DOV, *DIMOVERRIDE
    DRR, *DRAWORDER
    DRA, *DIMRADIUS
    DRE, *DIMREASSOCIATE
    DRM, *DRAWINGRECOVERY
    DS, *DSETTINGS
    DST, *DIMSTYLE
    DV, *DVIEW
    E, *ERASE
    ED, *DDEDIT
    EL, *ELLIPSE
    ER, *EXTERNALREFERENCES
    EX, *EXTEND
    EXIT, *QUIT
    EXP, *EXPORT
    EXT, *EXTRUDE
    F, *FILLET
    FI, *FILTER
    FSHOT, *FLATSHOT
    G, *GROUP
    -G, *-GROUP
    GD, *GRADIENT
    GEO, *GEOGRAPHICLOCATION
    GR, *DDGRIPS
    H, *HATCH
    -H, *-HATCH
    HE, *HATCHEDIT
    HI, *HIDE
    I, *INSERT
    -I, *-INSERT
    IAD, *IMAGEADJUST
    IAT, *IMAGEATTACH
    ICL, *IMAGECLIP
    IM, *IMAGE
    -IM, *-IMAGE
    IMP, *IMPORT
    IN, *INTERSECT
    INF, *INTERFERE
    IO, *INSERTOBJ
    J, *JOIN
    L, *LINE
    LA, *LAYER
    -LA, *-LAYER
    LE, *QLEADER
    LEN, *LENGTHEN
    LI, *LIST
    LINEWEIGHT, *LWEIGHT
    LO, *-LAYOUT
    LS, *LIST
    LT, *LINETYPE
    -LT, *-LINETYPE
    LTYPE, *LINETYPE
    -LTYPE, *-LINETYPE
    LTS, *LTSCALE
    LW, *LWEIGHT
    M, *MOVE
    MA, *MATCHPROP
    MAT, *MATERIALS
    ME, *MEASURE
    MI, *MIRROR
    ML, *MLINE
    MO, *PROPERTIES
    MS, *MSPACE
    MSM, *MARKUP
    MT, *MTEXT
    MV, *MVIEW
    NORTH, *GEOGRAPHICLOCATION
    NORTHDIR, *GEOGRAPHICLOCATION
    O, *OFFSET
    OP, *OPTIONS
    ORBIT, *3DORBIT
    OS, *OSNAP
    -OS, *-OSNAP
    P, *PAN
    -P, *-PAN
    PA, *PASTESPEC
    PARAM, *BPARAMETER
    PARTIALOPEN, *-PARTIALOPEN
    PE, *PEDIT
    PL, *PLINE
    PO, *POINT
    POL, *POLYGON
    PR, *PROPERTIES
    PRCLOSE, *PROPERTIESCLOSE
    PROPS, *PROPERTIES
    PRE, *PREVIEW
    PRINT, *PLOT
    PS, *PSPACE
    PSOLID, *POLYSOLID
    PTW, *PUBLISHTOWEB
    PU, *PURGE
    -PU, *-PURGE
    PYR, *PYRAMID
    QC, *QUICKCALC
    R, *REDRAW
    RA, *REDRAWALL
    RC, *RENDERCROP
    RE, *REGEN
    REA, *REGENALL
    REC, *RECTANG
    REG, *REGION
    REN, *RENAME
    -REN, *-RENAME
    REV, *REVOLVE
    RO, *ROTATE
    RP, *RENDERPRESETS
    RPR, *RPREF
    RR, *RENDER
    RW, *RENDERWIN
    S, *STRETCH
    SC, *SCALE
    SCR, *SCRIPT
    SE, *DSETTINGS
    SEC, *SECTION
    SET, *SETVAR
    SHA, *SHADEMODE
    SL, *SLICE
    SN, *SNAP
    SO, *SOLID
    SP, *SPELL
    SPL, *SPLINE
    SPLANE, *SECTIONPLANE
    SPE, *SPLINEDIT
    SSM, *SHEETSET
    ST, *STYLE
    STA, *STANDARDS
    SU, *SUBTRACT
    T, *MTEXT
    -T, *-MTEXT
    TA, *TABLET
    TB, *TABLE
    TH, *THICKNESS
    TI, *TILEMODE
    TO, *TOOLBAR
    TOL, *TOLERANCE
    TOR, *TORUS
    TP, *TOOLPALETTES
    TR, *TRIM
    TS, *TABLESTYLE
    UC, *UCSMAN
    UN, *UNITS
    -UN, *-UNITS
    UNI, *UNION
    V, *VIEW
    -V, *-VIEW
    VP, *DDVPOINT
    -VP, *VPOINT
    VS, *VSCURRENT
    VSM, *VISUALSTYLES
    -VSM, *-VISUALSTYLES
    W, *WBLOCK
    -W, *-WBLOCK
    WE, *WEDGE
    X, *EXPLODE
    XA, *XATTACH
    XB, *XBIND
    -XB, *-XBIND
    XC, *XCLIP
    XL, *XLINE
    XR, *XREF
    -XR, *-XREF
    Z, *ZOOM
    把上面的替换掉acad.pgp文件里那些命令应该就可以了。
    2010-11-11 12:05:11
CAD下载及教程
52.09 万条内容 · 690 人订阅
结构师请进。。。
大家嗮一嗮自己用的画图插件吧。。。。
