土木在线论坛 \ 建筑结构 \ 结构资料库 \ 悬索桥气弹性稳定CFD分析(英文)
悬索桥气弹性稳定CFD分析(英文)
发布于:2010-11-04 14:37:04 来自:建筑结构/结构资料库 [复制转发]
论文简介:
As a consequence large deformations at the mid-span can occur with risk of aeroelastic instability and structural failure. Analysis of aeroelastic stability also named flutter stability is mostly based on semi-empirical engineering models, where model specific parameters, the so-called flutter derivatives, need calibration from wind tunnel tests or numerical methods. Several papers have been written about calibration of flutter derivatives using CFD models and the aeroelastic stability boundary has been successfully determined when comparing two-dimensional flow situations using wind tunnel test data and CFD methods for the flow solution and two-degrees-of-freedom structural models in translation perpendicular to the flow direction and rotation around the span axis of the bridge section.
附件名:20101141288852676067.zip
文件大小:779K
(升级VIP 如何赚取土木币)
结构资料库
41.29 万条内容 · 428 人订阅
斜拉索线形设计
论文简介: 对现有拉索线形计算理论进行了研究,系统的给出了不同精度斜拉索线形参数求解公式,计算了梁济运河大桥斜拉索的设计线形,对比分析了其线形参数的精度,得出对于200m左右跨径的斜拉桥可采用无弹性理论计算斜拉索线形的结论。 附件名:20101141288852250246.zip 文件大小:147K (升级VIP 如何赚取土木币)
