土木在线论坛 \ 电气工程 \ 供配电技术 \ 拜求配电箱电缆尺寸
拜求配电箱电缆尺寸
发布于:2010-10-18 16:33:18 来自:电气工程/供配电技术 [复制转发]
[ size=5]各位大虾,请问1200安培的主配电箱要分别接在600安培,400,250,225,100安培的分箱上面,电缆尺寸是多少啊? 电压120/208伏。这是位客户问我的,小女子完全不懂,拜请各位专家赐教。
英文原文: i will install one 1200 Amp panel box for each two generators
Enayatullah faryabi: i dont know what size cable i should run from generators to panel
Enayatullah faryabi: and, also i need to run cables from the 1200 amp panel to one 600 amp breaker, to one 400 amp breaker, and to two 250 amp breaker, i dont know the cable sizes to run
also, i need to run a power cable from the 1200 amp main panel to 400 amp subpanel, i dont the cable size, i mean what size should be used?
the cable should be five core, three hot, one neutral, one ground
Enayatullah faryabi: also, the voltage is 120/208 volts
qq邮箱 996687113@qq.com
全部回复(10 )
  • lingxuct
    lingxuct 沙发
    有图要比文字说明清楚多了,E文不懂。
    2010-10-20 17:03:20
  • cherryflower
    cherryflower 板凳
    想买1200A 的配电箱2台 哪里才有卖啊
    2010-10-20 14:03:20
97.93 万条内容 · 2230 人订阅
关于密闭肋的疑问!!!
防空地下室过密闭隔墙时设密闭肋吗?暗敷管线沿顶棚过密闭隔墙时设吗,还是明敷管线才设? 还是密闭肋仅过防护密闭墙及围护结构时才设? 密闭肋属于防护密闭措施还是密闭措施?
