土木在线论坛 \ 环保工程 \ 规范资料 \ 一般在什么情况下泵后出水管需要加装可屈挠接头?
发布于:2006-02-13 18:17:13 来自:环保工程/规范资料 [复制转发]
小管径有没有加装的需要,不加行么?
规范资料
10.99 万条内容 · 246 人订阅
Design UASB
Design of an UASB Reactor Guest article by Dr. Makarand M. Ghangrekar, IITUASB ProcessUpflow Anaerobic Sludge Blanket (UASB) reactor has been successfully used to treat variety of industrial as well as domestic wastewaters. The UASB reactor can be briefly described as a system in which substrate passes first through an expanded sludge bed containing a high concentration of biomass. The sludge in the reactor may exist in granular or flocculent form, but the granular sludge offers advantages over flocculent sludge. Most of the substrate removal takes place in sludge bed. The remaining portion of the substrate passes through a less dense biomass, called the sludge blanket.
