土木在线论坛 \ 水利工程 \ 农田土整 \ 关于喷灌的问题
关于喷灌的问题
发布于:2006-02-04 15:39:04 来自:水利工程/农田土整 [复制转发]
请教大家,在喷灌中,已知喷头和主管的直径以及主管处的压强怎么求喷水量和喷出的水速呀
或者去哪找资料
谢谢大家
There are a wide variety of techniques available for irrigating a field. The technologies range from advanced drip systems to periodic flooding. One of the systems that is used on smaller ranches is the use of "hand move" irrigation systems. Lightweight aluminum pipes with sprinkler heads are put in place across fields, and they are moved by hand at periodic intervals to insure that the whole field receives an adequate amount of water. This type of irrigation system is cheaper and easier to maintain than other systems. It is also flexible, allowing for use on a wide variety of fields and crops. The disadvantage is that it requires a great deal of time and effort to move and set up the equipment at regular intervals.
Given that this type of irrigation system is to be used, how can it be configured to minimize the amount of time required to irrigate a field that is 80 meters by 30 meters? For this task you are asked to find an algorithm to determine how to irrigate the rectangular field that minimizes the amount of time required by a rancher to maintain the irrigation system. One pipe set is used in the field. You should determine the number of sprinklers and the spacing between sprinklers, and you should find a schedule to move the pipes, including where to move them.
A pipe set consists of a number of pipes that can be connected together in a straight line. Each pipe has a 10 cm inner diameter with rotating spray nozzles that have a 0.6 cm inner diameter. When put together the resulting pipe is 20 meters long. At the water source, the pressure is 420 Kilo- Pascal and has a flow rate of 150 liters per minute. No part of the field should receive more than 0.75 cm per hour of water, and each part of the field should receive at least 2 centimeters of water every 4 days. The total amount of water should be applied as uniformly as possible
  • toro
    toro 沙发
    有专门公式的,在给排水的基本资料里都有.不过由于公式很复杂,一般我们都在电脑里设好公式,让电脑算.
    2006-02-06 09:45:06
农田土整
5.03 万条内容 · 135 人订阅
饮水安全的讨论
大家讨论一下饮水安全问题
